At Home In The Woods
   / At Home In The Woods #3,621
Obed -
To clear up some of the confusion, there are two common types of "hammer drills". One is a rotary percussion drill, which basically is a motor turning a shaft and with a piston actuator, which is made to drill concrete. It drills mainly by striking the concrete with the bit, but also turns the bit to eject the spoils. The second type is a drill that has a sawtooth mechanism that causes the chuck to move in and out a small amount, and primarily drills by turning the bit, but that action is aided by the ratchet mechanism.
The rotary percussion drills typically use spline or sds shank bits, and those are specially shanked to fit a specially designed chucks, which much heavier duty than a typical twist drill chuck. Twist drills are used in a non-percussion drills with a standard chuck, and are lighter duty.
Both work fine for smaller holes, and as a matter of fact, for tapcons, twist bits are much more commonly available and used. Bosch for instance makes some called "blue granite" which are sold at Lowes.
For larger holes in concrete, rotary percussion drills are typically used with their special chucks (sds or spline).
Tom
Obed -
Tom
Tom,
Thanks for the clarification. My drill is obviously the lighter duty tool. It had no trouble using the Ace hardware bit to drill 5/32" dia holes in the concrete wall. I have rented large drills to drill 1 1/2" holes through our poured concrete retaining wall. I wouldn't consider using the little Ace HW bit in that larger beast of a drill.
Obed
   / At Home In The Woods #3,623
Yeah you will be fine for your uses with bits like that. If you run into a major project, it will be worth renting a big boy SDS or one of the other variants.
I see you are coming around on segregating your firewood too! Like I noted before, it is easier if you separate it into 2-3 groups of good better best, then you can pull from whichever pile to make your desired mix. So perhaps lump the oak and hickory together, the midgrade maple/birch/poplar, and then the light stuff like pine or basswood. Adjusting to whatever types of wood you have or run into.
Merry Christmas!
Today was a beautiful day to be outside cutting wood. The temps were in the 40s and the sky was blue. I thoroughly enjoyed working outside today. I needed some more hard heavy wood for the fireplace. Too much of the wood I recently cut was lighter wood (pine, poplar).
I picked out two logs from the log pile, a hickory and a white oak. I wrapped a chain around the hickory and pulled it off the pile. I didn't like how the end of the log was digging into the dirt as I pulled the log so I put a small log on the ground to get the hickory log out of the dirt.
I used my log peavey to roll the logs. I love this tool. I cut the hickory into two 7 1/2 foot logs and one 9 foot log. Unfortunately, those logs were too large for me to easily manuever. After I started moving them, I regretted not cutting them in 6 ft sections. I had to man-handle these logs to get them on the tractor's fork. However, I found out that my FEL would lift more than two of the heavy hickory log sections.
After I got the three hickory logs positioned where the tractor could pick them up, I then pulled the white oak off pile and cut it into 6 ft. sections. I had to cut off the stump before I could pull the white oak off the pile. It took 3 trips to carry the log sections to my splitting area uphill from the house.
I used the 14" chainsaw to cut the logs into sections at the log pile. However, the hickoy log was almost to big for the small chainsaw. I brought out my 20" chainsaw to cut the wood into 18" sections. The larger saw cuts logs much faster than the smaller saw. In order to be nice to my lower back, I squatted with both knees fully bent while cutting with the larger saw.
I filled 1 1/2 pallets today plus I still have several 18" long logs that will need splitting.
Merry Christmas,
Obed
Merry Christmas!
Dave,
Yes I remembered your comments about segregating it. That might work out best. I'm sure I'll be experimenting quite a bit until I find a system I'm satisfied with.
Obed
   / At Home In The Woods #3,626
Curious how long the pile of wood you are taking logs from has been sitting?
It looks like the wood is very likely real wet from the look of all the moss and other signs of aging?
I mention this because if that wood is as wet as it looks it may be keeping you from getting the kind of fireplace burn you're seeking, even if you are mixing it with other dryer wood. The problem with burning wood with high moisture content is that you are creating creosote, and the wet wood is reducing your overall heat output due to energy being expended to remove the water from the wood instead of heating your house. The creosote coating your stovepipe is the worst part because it is the main source of chimney fires when it catches fire, and it is near impossible to put out without fire dept. assistance. There are fireplace chimney fire extinguishers in the shape of a stick that are readily available to deal with small chimney fires and I suggest you keep one near your fireplace in case of need. They smother the fire to keep it from doing extreme damage.
Depending on how long those logs are you could save your back even further if you chained a log and pulled it out of the pile to about the tipping point and then cut off sections to length, (say 18-24") and let them fall to the ground, and then split the sections, instead of wrestling 6-8' log lengths and then having to transport them and then cut to fireplace size, and then split.
   / At Home In The Woods #3,627
My wife attached one 2x4 to the concrete wall yesterday before her masonry bit broke. Today I continued where she left off. I attached the two remaining 2x4s to the wall. I have to say I was a bit apprehensive about screwing the 2x4s to the poured concrete wall. I've never done it. I remember the subs mentioning using Tapcon screws when we built the house. So we bought some and using them was actually pretty easy. Using a new masonry bit, I set the drill on hammer and had no problem drilling the holes and screwing the boards to the concrete. We put pressure treated spacers between the 2x4s and the concrete to keep the untreated wood off the concrete.
The shelves we are building now are more complicated than the first set of shelves. These shelves are in a corner whereas the other shelves were on a straight wakk. I admit I scratched my head for a while getting a plan together for how to build the frame for the shelves. I eventually put down a plan on paper. I cut the frame boards for the first shelf. I then laid them all out on the floor to make sure all the measurements worked right. On board was 1/4 too short so I modified my drawing accordingly. I then started cutting boards. I labeled each board A, B, C, D, E, F as I cut them to simplify assembling them.
I may watch to much Holmes on Homes or Homes inspection but he would have a fit with your untreated wood next to concrete or with no gasket. Any moisture trapped there will mold or cause rot.
As far as your observations for hickory, you are correct, but its denser than Oak and since you have a splitter it really dosent matter much, you can always turn it over and split again if you can pull apart. Burining in an open fireplace hickory pops way to much and sparks out even through a screen.
As much as you like a fire and you like to burn and cut wood i still am miffed why you did not put in a wood Insert or make a freestanding wood stove and heat your entire house on the same amount of wood and not need supplemental heat. Like i have said before i heam pretty much my entire home except the most extreme days with only my wood stove, my home only has r19 attic insulation, nothing else and is 2500sqft. I can keep it about 65 in the farthest room, our bedrooms the others are in the 70's and the tv room can be in the 80s or high 70s with the insert.
I know its to late now as you bought that stove and a good insert will run you over $2K but i would have gone that route.
   / At Home In The Woods #3,628
Merry Christmas,
Obed
I love how detailed you are. I chuckle to my self reading your posts. Are you sure your not a police detective or some secret agent and your other job is a cover story?
   / At Home In The Woods #3,629
I was thinking the same thing.
The other thing i do is to cut them up in the pile, you dont have to much binding to worry about and you dont worry about dirt as there on onther logs, all you need to be sure you dont do is get the tip in another log and cause the saw to kick back. But modern saws have a inertia chain break that activates if this happens.
We put pressure treated wood spacers between the 2x4s and the concrete. Please re-read the post and you'll see where I mentioned it. There is also a picture that shows the spacer behind the 2x4.
We have a high-efficiency fireplace. It's a Quadrafire 7100. Please read up on it. It heats our entire house - 2100 SF all on one floor. The great room/living room where the fireplace is located stays between 72 F and 75 F, even in the mornings before the fireplace has been reloaded. Since I've started stoking the FP at night with hickory, the bedrooms, which are the coldest rooms in the house, are 68 F, even in the early mornings. We don't run the heat pump or gas furnace when the FP is burning. The only times we've turned on the heat pump or furnace this winter has been when the outdoor temps were too warm to burn a fire in the house.
Yes, a heat stove can put out more heat in the room. However, I can't imaging wanting more heat in our our living room. We struggle some times to keep the great room cool enough. I figure 72F in the great room and 68F in the bedrooms to be an almost ideal heat distribution without using a furnace.
Obed
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2019 Ford F-150...
2005 Takeuchi TB135 (A55272)
2005 Takeuchi...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2021 Ditch Witch SK800 Mini Skid Steer Loader (A57453)
2021 Ditch Witch...
