At Home In The Woods
   / At Home In The Woods #801
I use a coil nail gun for shingles, but I'm not a roofer and don't want to be. I've done quite a bit of repair work and find staples to be the very worse. They consistantly go right through though the shingle. With the nail gun, two things seem to cause most of the problems. Too much pressure that drives the nailhead through the shingle, and using too short of a nail. If the shank doesn't go through the underlayment, it won't hold. With every roof, here will be those soft spots were the nail goes all the way through the shingle. I use a product called "Through the Roof" that's clear and very good at roof repairs, for fixing those areas that didn't nail properly.
There is one guy around here that I know of who does hand nailed roofs. He's more money, but of the few people that I know who have hired him, they are all extremely pleased with the results. Of the dozens and dozens of roofers in my area, there are only a few that I know of that I'd recomend to my clients.
When hiring a roofer, you must specify every detail. Never rely on the roofer to do it the best way possible. He has all sorts of ways to cut corners that you will not know about for the next ten years. He bids the job at a price and every corner that he cuts, he makes more money.
On existing homes, always strip it down to the wood. Too many leave the paper on and can't inspect the sheething. You have to put new paper down anyway, so there's not good reason to leave the old paper on there except to make sure NOT to find any existing issues.
Require the use of the best, heaviest paper available. A good shortcut is to use 15lb paper. It's half the price, but it's junk and the life of the roof will be greatly affected.
Require valley flashing. Here, they try to use paper and shingles witout any metal in the valleys. This leads to leaks. It's not expensive or complicated to do, but it does add to time and materials to the job that the contractor can avoid doing and make more profit.
Specify nail length. Sadly, some will use 1 inch nails to save money. A one inch nail has to go through the shingles and the full thickness of the sheeting to be effective. The point of the nail needs to go completely through the wood in order for the shaft of the nail to have any holding power. If the tip of the nail is all that's in the wood, then it will come right out.
Specify exactly what shingles you want. Don't rely on the contractor to suggest any to you. Ask him what he has access to, and go take a look at them for yourself. If you don't like any of them, go find what you do like and specify that he use those. He can get anything that you can find, and there is no reason to settle for anything that you do not want.
The roof is the last place to save money. You don't need to go crazy, but to do it right, it will cost a bit more. Spend the money now and never have to worry about it later.
I had a client who told me they had 7 years experience roofing houses in Houston. I did the framing and sheething, but they were to do the shingles. They did everything wrong, cut every corner they could and when it was all said and done, they had ruined the house. Then the following year, they called me back to complain about several leaks. I went and looked, and it was because they cut the shingles in place after nailing them down. You can't cut shingles in place with a knife and not cut through the paper under the shingles !!!!
Ceilings are now stained and it's going to cost quite a bit to fix all of what's happened. I refused to get involved and haven't heard from them again.
Eddie
Obed, all details aside, that house is gonna be spectacular. I can easily envision the look and feel of it as you drive up your driveway. You must be very excited despite being stressed and tired. It will all pay off for you very soon. I just hope the weather gives you a few breaks and doesn't beat you up too badly.:)
Thanks for the encouragement, jinman. Sometimes it's hard to see the end for all the obstacles. I was a little down yesterday thinking about the house. But holding my new little girl sure helps take my mind off the "non-important" stuff. I've never been around babies or small children much. I've heard other people talk but I never actually knew how wonderful having a child could be.
Today the weather was incredible. It was sunny with a high of 57 F. Tonight I went outside; the stars were out and the moon was shining in a perfectly clear sky. It was extremely peaceful here being surrounded by the woods. It was nice to be able to spend a moment just enjoying.
Obed
Eddie,
The timing of your post could not be better. We are currently looking for a roofer. Thanks for the great ideas!
Obed
   / At Home In The Woods #804
I wonder how many roofers are going to nail by hand vs using a nail gun. I imagine not many and if so you'll pay dearly. I personally think you get a better job using a gun as it is less physical than hand nailing.
I agree. My roofer uses 5 nails on 3 tabs and 6 nails per shingle on architectural shingles. Never a issue. They put ice dam under the valleys and around the perimeter followed by felt then shingles.
All I have ever seen on any roofs around here is torn shingles due to the wind. No amount of nails or style of nailing is going to prevent that.
Chris
Here's a cleanout for the septic pipe that runs from the camper to the septic tank. When I installed the cleanout (http://www.tractorbynet.com/forums/projects/157965-home-woods-7.html#post1816307, I purposely did not fill the hole around the cleanout. I figured that by leaving the hole open, I might minimize the chance that a construction or delivery vehicle might back into the cleanout pipe. About a week later, the gravel delivery truck dumped gravel beside the cleanout and filled the hole with gravel. So much for my plans. Unfortunately, I had not glued the verticle pipe that connects to the cleanout joint. So today I removed the gravel out of the hole with a hand shovel and glued the verticle pipe to the cleanout. This picture shows gravel around the pipe before I started today.
The first thing I did was move this load of roofing felt. I had do move it by hand, one roll at a time. I moved the felt into the garage where it would be out of the way.
I've had a constant challenge with the building supply company unloading materials and blocking access to things. I wasn't able to get the tractor to the gravel pile near this pallet of felt for several weeks because of lumber that got unloaded in front of the gravel pile. If I'm at home when I hear the backup beeping of the delivery man's backhoe, I always run out there and make sure they leave room for parking our cars and leave a turn-around spot in the driveway. We have plenty of room in front of the house for materials but for some reason the delivery trucks keep dumping stuff in a spot that cuts off access to the front of the house. Then there's very little room to unload subsequent deliveries.
Here's the hole after I removed the gravel with my hand shovel. The picture doesn't look like much but that was a lot if hard digging. My back is tire this evening.
The wife gave me orders not to refill the hole with gravel but to put dirt in it. There were several inches of gravel beside the hole that I drug away with the boxblade. I used the boxblade as a bulldozer to push the gravel onto the gravel pile. The pipe is leaning over some; that's the way it was originally. Some pictures make the lean look worse than others because of the angle of the camera.
Here's the finished product. It doesn't seem like much but this project took several hours due to all the hand shovelling and a flat right front tire. I had to pump up the tire with a bicycle pump at the begining of this project. I left the tractor parked there to prevent building materials from getting unloaded at that spot again. This next weekend I need to grade the area where the back porch and deck will be located. I would have graded the porch and deck area weeks ago except I couldn't get my tractor to that spot because of the building materials.
   / At Home In The Woods #810
Obed,
Keep your chin up. It won't be long and you'll be looking at interior paint and trying to decide between eggshell and off-white. LOL
Give our best to the misses and the little one.
2024 KMC 7406 (A53084)
2011 Kenworth T800 Water Truck (A54865)
2011 Kenworth T800...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
TAKEUCHI TS50R SKID STEER (A52706)
TAKEUCHI TS50R...
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
