ATI Tach-All adapter for LA402 -- Pricing?
   / ATI Tach-All adapter for LA402 -- Pricing? #11
Many of the lighter weight grapples that are available can be ordered as a pin-on version specific to the LA402. They would otherwise pin on to the FEL arms like the bucket would. But if you go with the pin-type QA, you have a fairly easy way of swapping between the standard bucket and the grapple.
Do a search for RonJHall's pics in the photo gallery. He has the LA402 on his B2910, and has the Kubota pin-type QA. Two hooks on the top, and you pull the pins on the bottom two holes.
Take a look at the hydro fittings on your buddy's skid steer, and you'll see that they're different than the B7800 fittings.
   / ATI Tach-All adapter for LA402 -- Pricing? #12
z0lt3c said:
I was told their wasn't a grapple bucket available for the LA402 unless you went w/ a skid steer QA... now I'm not sure if thats true or not. Do I have other options besides skid q/A to get a grapple bucket? I didn't think the Kubota Q/A was any help because I don't need the forks or snowblower, which I was told were my only options.
quote]
I believe Millonzi and others will custom make a pin on type grapple mount if you provide the measurements to them. There are also grapples that mount directly to the bucket by either bolts or welding. The benefit of a skid steer type mount though from my point of view is if you ever upgrade you can still use the same attachments. If you go to a loader specific pin type mount you would have to sell the attachments with the tractor or try and find someone with a similar setup to sell them to. The skid steer type mount attachments also have a better resale as more customer's can use them. That is the primary reason I went with a skid steer mount on my B3030. I switch between my bucket, grapple and pallet forks quite often. If I ever upgrade ( l love the new Grand L's) I can take my grapple and forks with me.
Well I just got back from the dealer w/ the itemized invoice for ATI Q/A. The pricing on the ATI Q/A system itself was inline w/ other posts I've seen, around $700. However, they wanted almost $500 for the welding labor and $200 for the blank to add the ATI plates to my factory kubota bucket. They broke it out as 6 hours of welding labor at $75/hr plus tax. That seems like alot of labor $$ for 1 bucket. I wonder how much of that the welder actually sees!
I went ahead and ordered the Q/A but I told them not to order the blanks nor adapt my old bucket. I think I am going to try and sell my old bucket on ebay and/or locally and then just got buy an ATI bucket, or similar, w/ the skid steer q/a already attached. That grapple bucket for $1000 somebody suggested would be perfect and would not cost me anymore once you consider the $700 savings plus about $400 value for my old bucket.
   / ATI Tach-All adapter for LA402 -- Pricing? #14
Like i had mentioned earlier, a dealer here quoted a little over six hundred for a HD bucket with bolt-on cutting edge. I think you made the right choice. Either check with a couple welding shops on converting yours, or sell it and buy a QA bucket.
Good news is that I found a bucket locally for $400, going to pick it up on Sunday. Also, ATI Tach-All come in today and I had a chance to install it, really simply install, took all of 45 minutes. Just need to buy a grease gun to grease up the pins. Pics of the Tach-All are below.
I have my original bucket B1617 60" bucket for sale if anybody is interested, PM me. See the following link for more details; Kubota 60" B1617 Bucket for LA401 and LA402 loaders
   / ATI Tach-All adapter for LA402 -- Pricing? #16
Nice ! I need one now. Did you order that through your tractor dealer?
Although reluctantly, my local Kubota dealer did order the ATI system for me. Here is the breakdown;
ATI QA-KU1 Tach-All $650
ATI pin kit for B7800 $75
Freight $20
$745
My dealer had already ordered the blank plate to retrofit my bucket before I canceled, so he stuck me with the cost of the plate claiming it could not be returned.
AP-250-U Attach Plate $195
Freight $20
$215
My total out of pocket was $960 and I was allowed to include this cost in my tractor financing at 0%/42mo.
I'm debating what to do with the blank plate, $195 was a rip-off for this plate as I've seen it on ebay for $85. I may have it welded onto a 1000# set of TSC 3pt pallet forks and retrofit them to work w/ the front loader.
   / ATI Tach-All adapter for LA402 -- Pricing? #18
Hang onto that extra QA plate........ you'll find a use for it ! You will eventually want a second bucket with teeth, forks, larger snow bucket, etc,etc.!! I can think of about twenty things i'd like to be able to attach to my loader.About 2 beans with shipping is about average on those around here, so i don't feel they way-overcharged you.
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
UNUSED 3.5X2X2M GREEHOUSE (A54757)
UNUSED 3.5X2X2M...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
