Attaching PTO
   / Attaching PTO #21
Another vote for Fluid Film! Also, spray it on the underside of your mower deck - grass just falls off! Makes cleanup after mowing a breeze.
   / Attaching PTO #22
You know, you could get one of these Pto Adapter 1-3/8 X6 Spline Male X 1-3/8X6 Spline Female Pto Adapter and swap it out between PTO drive shafts. That way, you'd have the push pin lock on all your PTO drive shafts.
Just make sure you can handle the extra 4" of overlap without bottoming out the drive shaft.
Foggy, I can't recall if you have a quick hitch or a Pat's Easy Change...but if you do, adding the adapter will just make up for the extra length of the PEC or QH.
You've got a great idea there Roy! Yes, I do have the PAT's on my 3 point....and in fact I bought that adapter / extension last year as I have one implement where I was concerned about enough PTO shaft length.
I just never considered using this adapter for those fugly collar set ups. Duh! :eek: GOOD SOLUTION ROY!!....That idea is going to save a few cuss words this next season! Thank You Roy!! :thumbsup::)
   / Attaching PTO #23
Just another service from YOUR friends on TBN!!
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2016 CATERPILLAR 259D SKID STEER (A60429)
2016 CATERPILLAR...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 BOBCAT T870 SKID STEER (A60429)
2021 BOBCAT T870...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
