Attaching sprocket to pipe
   / Attaching sprocket to pipe
good plan except, that pin is going to take a lot of shear force.
Shear pins for a baler would make it the weak easily fixable point. IIRC the shear pins for a massey baler were 1/4" with a squished nut. Other than that anything other than a grade 8 bolt is going to break quickly. Don't expect a roll pin or split pin to survive long.
I'm using a grade 8 1" bolt hardened
   / Attaching sprocket to pipe #12
Don't use pipe. Use a DOM tube. (Drawn Over Mandrel). For pipe, the id is controlled. For tube the OD is precise. Then you can shop some TSC parts to put the sprocket and its hub on the tube with a sufficient sized roll pin. I just bought a 2-1/4" DOM tube from an eBay seller for my extra Rol-A-Bin that's true, straight and exact.
If you can find an old hay/grain elevator, the parts you need for a powered hose reel are all there.
   / Attaching sprocket to pipe #13
   / Attaching sprocket to pipe #14
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
