Attaching wire feed to a stick welder
   / Attaching wire feed to a stick welder
I understand how you connected the two machines
I am wanting to weld a lot of 1/2in plate. I could stick weld it, but shakey hands gives me problems. I can control a mig gun much better than a long rod. I know I can buy a .045 roller for my 175 mig, I currently run .035, and I could turn the heat up on my stick welder to 250amp if I needed to. I expect I would have to do a little fignigeling figureing out the right settings. Not sure what kind of voltage my stick would throw at the wire, might be able to do spray transfer. I am thinking if I use the stickwelder set up on tig, I could add a wire from the mig trigger to the tig plug to automaticly turn the stick on/off so the mig gun wouldnt be hot all the time. Lots of things there I am not sure about.
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
(28) 4' FLOURESENT LIGHT CEILING FIXTURES (A54757)
(28) 4' FLOURESENT...
2017 John Deere 5090GN (A53317)
2017 John Deere...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53485)
THIS WILL BE A...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
