B 7100 HST PTO shift lock
/ B 7100 HST PTO shift lock #1
860thomasb
Connecticut
198? Kubota B7100 hst d
I'm using the rear PTO on my tractor for the first time drilling post holes with a lienbach PHD. The PTO shifter gets locked up and will not disengage. I have been able to disengage the PTO by shutting down the engine(but that doesn't always work), Putting the tractor in gear and moving forward and backward, ( again doesn't always work). My question is: is this common or should I expect the problem will get worse until the pto will not disengage at all?
/ B 7100 HST PTO shift lock #3
Does it do this only with the PHD on or will it also act this way when there is implement attached to the PTO?
Egon
/ B 7100 HST PTO shift lock #4
Egon
Hi EGON, This is the first time I've actually used the PTO. I tested it a couple of times with nothing attached and it worked fine shifting between rear to neutral and mid/rear combo to neutral.
/ B 7100 HST PTO shift lock #7
Sounds like all will be okay. Maybe with the attachment on the gears have to be moved slightly before it engages smoothly. /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
/ B 7100 HST PTO shift lock #8
/ B 7100 HST PTO shift lock #9
On my B7300 the PTO lever slides easily from the engaged position unless there is a heavy load on it. I presume you are depressing the clutch when trying to release it? I often slide mine from engaged to neutral when using my brush hog, and as long as the blades are completely unloaded I don't need to use my clutch. But if they aren't, I get some resistance (and then use the clutch).
/ B 7100 HST PTO shift lock #10
2019 CATERPILLAR 336 EXCAVATOR (A60429)
2019 CATERPILLAR...
2016 JLG T350 TOWABLE BOOM LIFT (A60429)
2016 JLG T350...
KUBOTA GR2100 RIDING LAWNMOWER (A60430)
KUBOTA GR2100...
2011 KUBOTA U25 SUPER SERIES EXCAVATOR (A60429)
2011 KUBOTA U25...
ASSET DESCRIPTIONS & CONDITION (A59904)
ASSET DESCRIPTIONS...
UNUSED FUTURE QSJ HYD MINI SWEEPER (A60432)
UNUSED FUTURE QSJ...
