B2150 TLB w/ 1500hrs for $12,500???
   / B2150 TLB w/ 1500hrs for $12,500??? #1
Briar
New here, wondering if this sounds like a good deal or not. I don't really "need" the backhoe right now... but I'm sure I could find some use for it. Any responses would be appreciated. Thanks
   / B2150 TLB w/ 1500hrs for $12,500??? #2
Briar,
I purchased a B2150DT (gear drive 4wd) with Kubota FEL and finish mower for $8K. It had 635 hrs. I thought i got a good deal. Would you consider selling the backhoe? I'd like to have one. e-mail me directly at jdrotert@nothnbut.net.
   / B2150 TLB w/ 1500hrs for $12,500??? #3
Briar,
Tried to get wife to allow me to get tractor with loader. Never got permission.
Stumbled onto an industrial backhoe/loader and she essentially "MAKES" me buy it (???) (seriously)
I had typically thought that a backhoe "might" be something interesting to have...of some beneficial uses...
Today, almost a year later I find that the hoe gets probably 80% of the usage and I can't really imagine having some machine without a hoe on the back.
Not only can the hoe work as a fancy wheel barrow similar to loader...but being articulated, can get into more complicated spaces than I can get my loader.
I can almost assure you that you will find some (many) uses for it should you keep it.
Richard
   / B2150 TLB w/ 1500hrs for $12,500??? #4
Many factors aside from hours will affect the 'deal' ... starting with:
- Transmission (HST (hydrostatic) = higher value; DT (gear) = lower value)
- Make/Model of Attachments (3rd party = lower value; Kubota LA350A loader and BL4690 backhoe = higher value)
- Tires (R1 (ag), R3 (turf), or possibly R4 (industrial) if retrofitted, those would increase the value over R1 or R3)
- Condition
- Previous use
- Service history
Carefully inspect a tractor like this, perhaps even by a professional if you don't have a lot of experience with compact tractors. I covered a fair bit about buying a used tractor and what to look for when doing a visual inspection yourself, in my book Compact Tractor Buying & Basics ...
Best of luck,
   / B2150 TLB w/ 1500hrs for $12,500??? #5
Briar,
Same here... If you are interested in selling the backhoe, let me know. Where are you located? I also have a B2150HST with bi-speed turn. Paid $13,000 w/60" belly mower & 6 ft blade. It only had 40 hours on it though. It was virtually brand new. The guy kept in his garage and washed & WAXED it every time he was done using it.
Thanks, Tim Pratzer pratzert@bcpl.net
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
2013 Toro Workman HDX Scissor Lift Utility Cart (A51691)
2013 Toro Workman...
BESTWAY AG LOT IDENTIFIER 20 (A53084)
BESTWAY AG LOT...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
