Tractor Sizing B2320 bush hog size
   / B2320 bush hog size #1
displacedPA
SC
NH T2310
Well the family and I moved to our new home place 19 acres. Half pasture half wooded. I have a b2320 and have been looking at bush hogs. I know manufacutre says 48" for hp and weight reasons. I'm looking a a bush hog sq148 if I can find one seems they stoped making this model. Or a bh14 48". Any other recomendations? If I could run a 54 or a 60 it would be nice because I may upgrade tractors at some point. Although I think the B is plenty up to the task.
   / B2320 bush hog size #2
I've spent a lot of time running a 5' bush hog on an 8n. You should be able to do it with the b. Especially if it's hydro, and you can slow down your ground speed and maintain PTO rpm. Make sure it'll lift it comfortably, and you should be alright.
   / B2320 bush hog size #3
I had the same ? with the purchase of my B2650 with 19.5 pto HP. and the dealer kept pushing the 5 FT. rotary cutter even though the book says 4 ft. . I bought the 5 ft. on the advice of the dealer and will just go a little slower . I havn't had a chance to use it yet so time will tell . He also pushed the 5 ft. snow blower so it will cover the wheel tracks and that is what I bought also . The beauty of hst is you can go as slower when needed .My dealer sells quite a few tractors so I took his advice .
The tractor is a hydro. I figured the weight of the fel and maybe a bucket full of gravel may help counter weight the front from the additional weight. The weight dif is only 200 lbs. I was more worried about hp. I alse have loaded rear tires not sure that makes a diffrence.
   / B2320 bush hog size #5
I have a B2620, purchased a landpride 5' "bushhog", in my opinion it was too heavy for the machine. I mowed with my FEL on or with front weights, it just seemed too heavy. Front end could come up pretty easy. If your ground is flat or rolling meadows without hills you would probably be okay. I finally sold my landpride and just use the MMM I purchased with the tractor. Others could have a different opinion, but mine is that the 5' landpride was too heavy.
   / B2320 bush hog size #6
I had a L235 with front end loader , 4 ft. rotary cutter 19.6 pto hp and had no problem with that at all . Didn't have loaded tires and the weight wasn't an issue . You shouldn't have any issue with the weight as you have a fel but pto hp. I don't know for sure . Much depends on how heavy the grass or hay will be . I run a 6 ft on M5700 with over 50 pto hp. and in really heavy hay I have to slow down quite a bit with that even .
   / B2320 bush hog size #7
Very interesting, thanks for your input . Did you have loaded rear tires ????? I do have a cab which adds about 500 lbs. , loaded tires and front weights so maybe that had some influence on the dealers decision in my case .
   / B2320 bush hog size #8
I've been mowing with rough cut rotary mowers using various tractor/mower combinations for over 40 years. Do not go beyond 4'.
SDT
   / B2320 bush hog size #9
I'd stick with a 4' cutter. The 2320 will run the 5' but it's going to struggle at times. The 4' will be cheaper, weigh less and you will be able to cut faster, making the difference in width of cut not too big of a deal.
4 foot it is. So called around bush hog bh 14 was 1500.00 called another guy 750 for a howse. I've heard negitive things about howse but no real personal expreiance. Bush hog I know is good also made in the usa. Any thoughts? I've also checked craigslsit but haven't found anything worth the money.
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A46683)
2015 Freightliner...
Hay Spear (A47809)
Hay Spear (A47809)
2020 Chevrolet Silverado 2500HD 4x4 Ext. Cab CM Truck Beds Service Truck (A45336)
2020 Chevrolet...
2016 KENWORTH T3 SERIES (A47001)
2016 KENWORTH T3...
1.5in Galvinized Pipe (A47809)
1.5in Galvinized...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A45336)
2021 JCB HM180T...
