B2X20 mowing survey
   / B2X20 mowing survey #1
ChuckinNH
Elite Member, R.I.P.
NH
(B2620, had BX22) Simplicity Legacy w/48" mmm
OK, I have a B2620, and because of some medical issues, I've been thinking about mowing with it. The deck on my garden tractor works well, but is difficult to R/R, and maintain the way I like to. So, here are the questions for those of you that do mow with this size tractor.
What tires do you have?
Do you find the drive over deck easy, or easier than other decks you have used to R/R, and maintain?
Is it a real pain to mow around obstacles?
Overall, what kind of review would you give this combination?
What size deck do you have, 54", or 60"?
I had thought about going to another mowing / garden tractor, and I can see an increase in manuverability over what I have ( a 10 yr old Simplicity Legacy) with some of them, but most look even harder to install the deck on. (Mine has the PTO shaft up front where it is pretty easy to reach. I've also thought about a BX to go with my B for just mowning, and snowblowing........... but I don't know that those decks are easier to handle either. I've also thought about a RFM, but I have MANY obstacles. ZTR's look good, but I need to be able to handle a trailer for wood chips from my chipper, and a hundred other things. Hard to pull a trailer with something usually mounted on the back of my B. Any input would really be appreciated. I mow just over 3 acres on a regular basis.
   / B2X20 mowing survey #2
Don't know what R/R is. It will come to me as soon as I hit submit reply.:) Beautiful property.
I had a B7800 and used a cheap $1200 6' RFM with it and it kept tearing up so Barlows gave me my $1200 back for it on the purchase of a $1700 6' Landpride. I have fairly steep hills and the Landpride would sort of swing the tractor at the bottom of the hill when I turned, it was/is heavy. It's still here waiting on Barlows to pick it up or me take it by when I go that way with my trailer. I loved the RFM for ease of service, attaching and unhooking. The only issue was remembering that with FEL and 6' deck I was pretty long and just had to remember that. It has the rear discharge which I like how it lays the grass down spread out instead of rowed because I some times waited a while before mowing, got pretty high sometimes.
Your tractor will handle a deck like this one or this one since Barlows has it for sale.
In my opinion, keep your other mower for around the house trimming and add a RFM to your B.
I had R/I4's on my B's and now on my BX25, turfs on mowing BX's and F.
   / B2X20 mowing survey #3
R/R ? not sure what that is either. remove/reinstall maybe? Like I said before- a BX MMM is easy but hard part is coupling the shaft. for someone who can't lift/push, crawl, I wouldn't recommend the MMM unless its a drive over type like john deer has. I can see your concerns with RFM, but its so much easier to hook, disconnect on a larger tractor like yours. My father has RFM on his MF1250 and use it regularly to mow . He does have a JD lawn tractor for smaller places though.
getting a BX just for mowing and snowblowing does sound attractive. As for size, 60 inch is easier to mow around trees, flower bed, etc due to less turning.
   / B2X20 mowing survey #4
Hi Chuck,
I think I have emailed you on this, but will chime in again:
What tires do you have? - R4's. You know the drill, try not to mow when the ground is too wet, watch the turns, and keep it out of 4wd and it does ok about not chewing up the grass.
Do you find the drive over deck easy, or easier than other decks you have used to R/R, and maintain? - It is pretty easy. You lower the wheels to minimum before removing it. Put the tractor in 4wd and ease it over. Comes off really easy. In putting it back on, the front is easy. The back is easy enough, just a matter of getting those lower control linkages lined up. Most difficult is reaching under there to hook up the PTO. Not that hard, but you are reaching from the side or laying on your back under neath.
Is it a real pain to mow around obstacles? It is very easy to mow around things. I think easier than using my JD GT245 because with the garden tractor when you back up, it disengages the mower. Not so with the Kubota. Biggest issue goes back to watching that tight steering on damp grass doesn't tear it up.
Overall, what kind of review would you give this combination? I think it does a good job, at least as good as the garden tractor. It is more comfortable to operate.
What size deck do you have, 54", or 60"? I have the 60"
You can lock the mower deck in the up position, so you have a fair amount of clearance. I used the tractor Sat to pull a trailer with a bunch of trees around to decide where we wanted to plant them and just left the deck on. But if I was going to do something like use the box blade, I tend to take it off and it is easy enough that I don't think much about it.
I take the FEL off to mow. I know you have the QA on yours, that that may me enough, but I worry to much about running the bucket into something especially when backing up.
There is always this debate on stability. Personally I wouldn't be likely to take the garden tractor into anywhere that I wouldn't take the B.
I have had no trouble with the deck. I use it some of the time at our house and often on our other property where I mow about 6 acres.
   / B2X20 mowing survey #5
I have a BX and use it to mow with a 60" deck. Its a great mower, but the deck is really heavy. I have lifted it up on the storage wheels myself but its really heavy. I have just jacked the BX with a floor jack and taken the blades off to sharpen them. To take the deck on and off isn't really that hard or physically demanding, just akward. It takes 5 minutes on a good day, 10 minutes on a bad day.
   / B2X20 mowing survey #6
I have a 60" on my BX. My MMM dolly makes it a cinch. The lighter 54" on the taller B should make R/R even easier. With the taller tractor, you could use bigger casters than I have on my dolly and you would find it amazingly easy. If you can't find the pics and description of my MMM dolly by searching the Kubota & Attachment archives, let me know & I'll find links.
I thought I wanted a NH with super-steer to get around obstacles, but that unbalances FEL loads. Just rocking back & forth on the pedal with HST, while changing the steering R/L @ the same time makes it quick & easy to mow around obstacles.
If I had the money, I'd buy the biggest F or ZTR I could for mowing and get a full sized UT for FEL, BH, brush hogging, etc. work. As it is, the BX is not the best at any one job, BUT it does get every job done at the most affordable price. For your medical situation with your tractor, the 54" MMM and a good dolly would serve you well. As for 3 acres of lawn mowing, that's a lot of time. You could go with a bigger deck to mow faster, but it's a tad more weight to maneuver @ R/R. If you don't have too many obstacles and the grass isn't too dense, could a gang-reel mower be feisable? That cuts more area faster.
R/R is remove, and replace. Mowing speed isn't a big issue since it is partly therapy, and I don't have to do it all at once. I appreciate all the input I'm getting here, and am open to any more folks might have. Yes, I have brought this up before, but my Yankee justification system rusted pretty bad over the winter, and I need it oiled. :D :D The commercial grade mower deck on my Simplicity weighs about 300# I guess, so the weight of these other mowers is about the same. The full width roller on the back of my deck makes it a bit tougher to slide. There are no hinged covers, grease fittings are underneath, etc. These days John Deere, and Simplicity use the same transaxle on the X700, and Legacy XL lines so the pto is in the same place on both, and very similar to the BX series. Nice thing about my Simplicity is that the cooling fan is high in the rear behind the seat. It is out of the way there, and cools you off when you are hitching up trailers, etc. Lets see, since I was supposed to be dead over a year ago, maybe I should just buy a ZD series to mow, a 4 wheeler to pull wagons, and a larger tractor to dig, and do serious play with. Yea, that's the ticket! :D
   / B2X20 mowing survey #8
Without question, I would get a front mount mower. Any of kubota's F series would be fine. New holland makes a nice one too.
When you get into the F series type of mowers, you're in a different class of mowers all together. They are not your mower boy's fast $12k ZTR, but more along the lines of industrial mowing. Often times these mowers are small tractors turned around with the 540 PTO hanging off the front and the steer tires on the back (drive tires on front). If I am not mistaken my F series mower is a BX2200 tractor. The mower decks are very heavy steel, gear boxes rebuilt-able, spindles are rebuilt-able and use grease (not sealed).
They are not quite zero turn but 12" turn radius. I have no problems mowing in stripes (back and forth) if I desire.
The power of the machine is fantastic. I've use mine to pull my 16' trailer (empty of course), hay rake ( new holland 256), and 5' wide lawn roller while mowing.
Mowing 12" tall grass is not a problem.
Speed is not a problem either. I find the mower can mow faster then I care to go.
Again, this is not your average mower. I graduated from a very expensive ZTR I kept tearing up.
Just my 2 cents....
   / B2X20 mowing survey #9
I have a 60" MMM for my 2920, it is pretty easy to R/R, 15 min at most. The cut is excellent even in deep thick grass/ brush:D. I have no complaints so far it is a quality piece of equipment and made really well. It is easy to mow around tree's and on hills as long as your rear's are filled. The plastic shoot discharge bends and flexes enough when you hit immovable objects (tree's). Good Luck!
   / B2X20 mowing survey #10
There you go, that's what I am doing too; well except for the ZD mower, my wife hates them so we have a BX2660 with 60" deck.
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
John Deere 5103 (A53317)
John Deere 5103...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
