Buying Advice B3200 for a church
   / B3200 for a church #21
The danger of a rotary cutter somewhat depends on what is in the brush being cut. I've seen a cutter throw a baseball sized rock 100 yards as fast as any pitcher I've ever seen. About once a year around here, someone gets run over by their tractor while bush hogging or the tractor flips over, etc.
If the ground being cut is all flat with no obstacles, that's one thing. If the ground has varying hills with unexpected drop offs, that's something else. Site conditions and operator experience are important factors to consider.
Nothing against flail mowers, but how is one safer in hills, unexpected drop offs etc.?
Many if not most farmers in my area use a 15' batwing rotary cutters in the hills as they will follow the undulations and are really good for mowing ditch banks, pond levies etc. State Highway Department also uses them and they mow with cars going right past them all day long in all manner of conditions.
I agree that operator experience is an important consideration and I am sure there are conditions in which one style will work better, just can't accept that flail mowers are all some profess them to be or rotary cutters as bad.
   / B3200 for a church #22
Typically the custodian should probably only use the tractor and whatever mower you chose when there is not anyone on the property. Just makes sense, since besides a mower throwing things, you shouldn't need to worry about church members wandering out to watch and you having to worry about running over them, their kids, or their pets. From an liability point of view, it only makes sense. Try to make sure the custodian carries a cell phone in case he needs to summon someone else, but otherwise, keep people out of the area, as well as parked cars. If you have invested in any expensive stained glass, a sheet of lexan over them isn't a bad idea to keep mowers and kids from tossing rocks at them.
Since the neighbor with the six foot bush hog hasn't had any problems with breaking windows, etc, you can expect about the same track record to continue. Just use a little common sense when you run a mower.
David from jax
   / B3200 for a church #23
Hello Triple R,
Candidly I was not attempting to demonize belly mowers or rear finish mowers
and I mentioned Iron horses mower story as an example only.
They fill a need for mowing with garden tractors and larger ag tractors.
And as the average garden tractor lawn mower is low in cost and the unit is designed with a low height belly mower the mower has to cost less.
The decks are stamped in a press and formed, the wind tunnel weldments are added and welded in place, wheel weldments are added,
holes drilled for arbor shafts and mounting holes, the arbors and pulleys added the decks painted and blades attached, the mower suspension is installed, belts installed and gaurds installed after the V belts are installed, and the mower is either installed on a waiting tractor and then crated and stored for shipment or the complete deck is stored in inventory for a tractor and installed later.
On occasion some buyers purchase two decks for their tractors to have a spare deck that is clean to mow with and allow the other one to be slid out and the clean one installed.
A family friend lost part of his foot when he slippped while using his push mower( no handle pressure kill switch on the old mower) and a cousins carelessness nearly killed his daughter with a leg wound.
About the Lexan, if the window has no has no venting the heat weakens the lead bed for the stained glass,- been there done that with our Tiffanies- a wood shutter is better anyway if they are short and exposed.
The small rotary belly mower is simply a means to an end for the lawn tractor owner due to the very low clearance height under the tractors frame and the mower was designed accordingly with the drive under the vertical engine crank shaft with a an electric clutch and V pulleys and flat pulleys to transfer the useable rotary eninge speed to the mower deck with and through spring tensioner pullies for shock load absorbsion and proper belt tension with the smaller units.
A flail mower has three weldments the side plates and the hood, the hitch mounts are welded after the hood and side weldments are welded together and bracing installed where required, the rear full width roller weldments added and then the full width rear roller.
The side weldments allow for quick drilling and precise positioning of the rotor bearing housing prior to welding the hood and side weldments together,
The gear box, gear box weldments, V belt drive and pulleys and or its chain drive and are welded in the proper location and belts or chain drive installed and the cover installed over the drive parts. the mower is crated and then stored etc.
The full width contact of the roller on the ground adds weight and stability to mowing and adds rigidity to the mower frame as well as reducing any twisting and racking of the mower body to zero with the weldments.
The last underbelly flail mower was made by Mott Mower for the International Harvester Lowboy high wheel Cub Cadet tractor from what I remember.
The Husquavarna folks now offer a front mounted flail mower for one of their garden tractors and it has two rows of knives I think. I am unsure if is available in the United States.
I would love to see permanent bar magnets in front of the tractor or belly mower or rear finish mower or 12 volt bar electromagnets, we can only do so much to protect ourselves from our selves
I dont wish to argue with anyone about mowers, I want everyone to succeed and not fail.
leonz
Thanks to everyone for your valuable input regarding our decision. We made a decision today and ordered an L2800 with FEL, 5' RFM, and 5' brush hog. All will be delivered tomorroe and they will deliver it tomorrow.
Thanks again for everyone's help.
Chris
   / B3200 for a church #25
Congratulations, I am sure it will provide good service for many years.
   / B3200 for a church #26
Chris
Hope you guys enjoy it, and can keep from getting into fights over who gets to do all the work around church with it. :D
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2025 DORSEY ALUMINUM FLATBED TRAILER (A59575)
2025 DORSEY...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
30ft Highway Trailer Co. Lowboy (A56436)
30ft Highway...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
FORD F-250 CREW CAB TRUCK (A59823)
FORD F-250 CREW...
