B7200 Block heater, drain pipe removal
   / B7200 Block heater, drain pipe removal #1
dontieche
Central Ohio
Ferguson TO 20, Kubota B7200 TLB, JD's 420, 214, Gator
Has anyone installed a block heater on a B7200?
I purchased the unit from my local dealer and it installs in place of the block drain pipe. The instructions reference a socket (70097-EN100) for removing the drain pipe (part # 15531-73170). All well and good except the dealer has never heard of the socket and I am unable to get more than a quarter turn towards getting it out. TIA
   / B7200 Block heater, drain pipe removal #2
Sorry I looked all thru my B7200 operators and workshop manuals and could not find anything on this. I will take a look at my 7200 next time I am out in the barn and see what it looks like.
I appreciate your response, I also have the factory service manuals and could find nothing. I am attaching the installation sheets for the heater in hopes that might help.
Thanks! That's the critter. For mine it shows the heater replacing the drain pipe.
   / B7200 Block heater, drain pipe removal #6
Hello:
Any luck getting it out -I am not sure either how to get it out without the socket.They put a bracket in a very bad spot welded to the frame near the drain fitting so it is not easy to get to.-Kip
   / B7200 Block heater, drain pipe removal #7
Hello, Did you ever figure out how to remove the drain plug? I was able to move a little with a 15/16" open end wrench but couldn't turn very far because jaws were obstructed. Really seem to need a special tool.
   / B7200 Block heater, drain pipe removal #8
You may have to bend a wrench or would a ratchet end box end work.:)
   / B7200 Block heater, drain pipe removal #9
Dontieche,
Here's Pics of mine installed......there's a pipe plug that needs a 17 mm allen wrench........IIRC a 1 3/8 socket fits the brass block heater......
If you don't touch the filler cap on the radiator you can slip the plug out and install the BH and only lose a cup or two of coolant (catch it in a pan to reuse it)
Good Luck
   / B7200 Block heater, drain pipe removal #10
After the picture it's very evident the box end will not work.:ashamed:
Afraid I missunderstood the question.:eek:
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
(2) TW 30 FORD WHEELS (A60432)
(2) TW 30 FORD...
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A60432)
UNUSED RAYTREE...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
