eBay/Craigslist Back hoe question
   / Back hoe question
I am not sure if there is a regen,,,,but it doesn't dump straight into the reservoir, it is some how intertwined with the 3 pt which, that's why I was blowing apart the return filters
   / Back hoe question #42
Did we know that before? Okay, the return MUST go directly back to the reservoir.
   / Back hoe question #43
Did you ever get the filter thing fixed?
The fluid should not go through the cannister low pressure filter and then to the 3pt. If your BH needs a filter, they make a high pressure inline filter.
All the fluid in the tractor is filtered, so any fluid going to the BH is filtered.
If you don't have a PB port on the BH valve, then you should not put a return line filter in the BH circuit, unless the TANK port is going directly to tank. .
This is a high pressure filter.
Surplus Center - SAE 8 12 GPM IN-LINE HIGH PRESSURE FILTER
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
JCB 270T T4 SKID STEER (A52705)
JCB 270T T4 SKID...
FAKE (A52472)
FAKE (A52472)
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
