BACKHOE ATTACHMENT??
/ BACKHOE ATTACHMENT?? #1
Bootstrap
Texas
john deere 4020
Anyone have experience with one? Best brands out there to look at? I am located in south Texas and it will be going on a 55hp tractor.
Thank you
/ BACKHOE ATTACHMENT?? #2
This is just one person's opinion, but when I bought my Kubota L3830 new I asked that it be equipped with a backhoe, and I was given a choice between a Kubota backhoe and a Woods brand backhoe. They looked to me to be of equal quality, but the Kubota backhoe hooked directly into the tractor's hydraulics, and the Woods backhoe had it's own seperate hydraulic oil tank, powered by a PTO-driven pump. I liked the idea of keeping the fluids separate, so I went with the Woods backhoe. It mounts to a subframe bolted to the frame of the tractor for strength. Digs 9'.
/ BACKHOE ATTACHMENT?? #3
What is the matching JD hoe for yours?
Thats the one I have been looking at. Any complaints? How hard is it to hook up? This will be used on a Case tractor.
Thank you
/ BACKHOE ATTACHMENT?? #5
most of the hoe i have used are / were heavy equipment.. however i have a woods 6500 at home on an old ford and it works JUST fine.
/ BACKHOE ATTACHMENT?? #6
I believe Woods are far better than Kioti or John Deer, OEM I would go with Kubota.
/ BACKHOE ATTACHMENT?? #7
In regard to how easy the backhoe is to mount to the tractor, it's very easy now, after a slight modification. Where the backhoe frame met the subframe on the tractor, the edges of the steel were sharp, square edges that could bind when you had it almost fit-up. I solved the problem by taking a hand grinder and chamfering all the mating edges so they'ed slide together when you got it close. Made life a lot easier.
Another advantage that the Woods had, was the Gannon bucket that they use has two options for pinning it to the boom. One is the normal digging position, and the other is the "power position", that slightly limits the range of motion of the bucket, but increases the leverage for more curling power, if you need it. I got an 18" bucket, a good compromise for the size of the hoe and tractor.
/ BACKHOE ATTACHMENT?? #8
I am looking at a Liberty light duty backhoe for my John Deere 790. The PTO has an 815 lb lifting capacity and the BH is 715 lbs. Somewhat concerned about the 3 point hitch stress. Has anyone done this or purchased a different make? If so I would like to hear your experience.
I looked at a Woods but they appear to be too heavy.
/ BACKHOE ATTACHMENT?? #9
I'm guessing your pto has -0- lifting capacity.. and the 3pt has that 8xx # capacity.
I usually mount a backhoe to a subframe or with lift full down or at least braced so the 3pt capacity is not used to support the hoe.
/ BACKHOE ATTACHMENT?? #10
I guess I expected the backhoe to support itself after I lower it to the ground and that the 3 point hitch would only be used to move it.
/ BACKHOE ATTACHMENT?? #11
Sorry - should have said my 3 point hitch has an 815 lb lifting capacity.
/ BACKHOE ATTACHMENT?? #12
the liberty backhoes look really nice.
/ BACKHOE ATTACHMENT?? #13
I just researched this before i settled on a subframe model. I think the woods or rhino with a sub frame would be your best option if u can stomach the price. It's amazing how much stress a backhoe can be on a tractor. 2 things; a lot of the backhoes weight is cantilevered rear word increasing stress on tractor. So even if u have the lift u risk bell housing or other damage during transport especially over rough terrain. 2nd. If outriggers loose footing or sink in soft ground and u don't catch it (it happens). All stress transfers to hitch and that can be a substantial force. Subframe helps a lot distributing this load.
10ft Cattle Panels (A64047)
10ft Cattle Panels...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2005 International 4400 Truck (A61573)
2005 International...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
Invoices (A63116)
Invoices (A63116)
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
