Backhoe Thumb Plans?
   / Backhoe Thumb Plans? #1
Johnny Glenn
88 Ford 555B
Thanks for looking in - I'm trying to find plans for making a thumb for a Ford 555 backhoe. I've seen plenty of DIY info but no dimensions of thumb and supporting hardware. Thickness of steel etc? I'm thinking of installing a mount using U-bolts and wondering where on boom should it go? The boom is standard size of 5ft long and 7 inches wide, the bucket is standard 2ft. Any ideas or links? Thanks.
   / Backhoe Thumb Plans? #2
me to!
Viewing a thread - Ford 555A backhoe
the above link notes 3/4" used
if it was me, i would skip idea of U bolts. i don't think i can even find one that would be strong enough. that and clearance of the bucket cylinder. you might be able to get some threaded rod 1/2" or bigger, with thumb on underside and a metal plate on top. but you would most likely still have clearance issues with the cylinder.
brackets or entire thumb i would say be welded on. check your local papers, generally someone will list welding for x price and come to you. vs you hauling tractor to them. at least that is how it is around here.
Thanks for the link -that thumb looks much easier to make than most I've seen! If you come across any other plans, please forward - thanks again.
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
Schulte XH1500 Series 4 15ft Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
30ft Highway Trailer Co. Lowboy (A56438)
30ft Highway...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
