Backhoe Thumb Plans?
/ Backhoe Thumb Plans? #1
Johnny Glenn
88 Ford 555B
Thanks for looking in - I'm trying to find plans for making a thumb for a Ford 555 backhoe. I've seen plenty of DIY info but no dimensions of thumb and supporting hardware. Thickness of steel etc? I'm thinking of installing a mount using U-bolts and wondering where on boom should it go? The boom is standard size of 5ft long and 7 inches wide, the bucket is standard 2ft. Any ideas or links? Thanks.
/ Backhoe Thumb Plans? #2
me to!
Viewing a thread - Ford 555A backhoe
the above link notes 3/4" used
if it was me, i would skip idea of U bolts. i don't think i can even find one that would be strong enough. that and clearance of the bucket cylinder. you might be able to get some threaded rod 1/2" or bigger, with thumb on underside and a metal plate on top. but you would most likely still have clearance issues with the cylinder.
brackets or entire thumb i would say be welded on. check your local papers, generally someone will list welding for x price and come to you. vs you hauling tractor to them. at least that is how it is around here.
Thanks for the link -that thumb looks much easier to make than most I've seen! If you come across any other plans, please forward - thanks again.
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
Marcrest BSP449 (A64127)
Marcrest BSP449...
