Backhoe Thumb Plans?
/ Backhoe Thumb Plans? #1
Johnny Glenn
88 Ford 555B
Thanks for looking in - I'm trying to find plans for making a thumb for a Ford 555 backhoe. I've seen plenty of DIY info but no dimensions of thumb and supporting hardware. Thickness of steel etc? I'm thinking of installing a mount using U-bolts and wondering where on boom should it go? The boom is standard size of 5ft long and 7 inches wide, the bucket is standard 2ft. Any ideas or links? Thanks.
/ Backhoe Thumb Plans? #2
me to!
Viewing a thread - Ford 555A backhoe
the above link notes 3/4" used
if it was me, i would skip idea of U bolts. i don't think i can even find one that would be strong enough. that and clearance of the bucket cylinder. you might be able to get some threaded rod 1/2" or bigger, with thumb on underside and a metal plate on top. but you would most likely still have clearance issues with the cylinder.
brackets or entire thumb i would say be welded on. check your local papers, generally someone will list welding for x price and come to you. vs you hauling tractor to them. at least that is how it is around here.
Thanks for the link -that thumb looks much easier to make than most I've seen! If you come across any other plans, please forward - thanks again.
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
8' DISC HARROW (A60430)
8' DISC HARROW...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2022 EZ-GO ELITE...
2020 HONDA PIONEER 1000 RTV (A64280)
2020 HONDA PIONEER...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
