backhoe
   / backhoe #11
I have a sub frame for the backhoes on my Mahindra and Kioti. I have had the Mahindra stuck so bad I had to pick up the tractor with the backhoe and keep moving the tractor to turn it around 180 degrees. I am not sure I could have done that with a 3PH unit.
A lot depends on how much you want to use it and the type of soils.
I use the backhoe the most and the soils are clay with a lot of rocks.
I can't tell you if I would have a problem with a MMM as I have a rear finnish mower.
talk with a dealer, see what they tell you.
There going to know if there will be a mounting problem.
Dave in NH
Mahindra 2810HST Kioti DK-40
   / backhoe #12
aloha,
</font><font color="blue" class="small">( The Woods subframe forward mount attaches to fittings which are part of the LA402 main frame, the rear attachment is to the 3PH "pin lower link." When the subframe is removed, it leaves nothing attached to the tractor to reduce your ground clearance or interfere with other attachments. )</font>
What year tractor & backhoe do you have? I have a Woods 7500 on my B2910, bought both in 2000. The sub-frame on the backhoe attaches to a bracket added to the loader frame. This bracket remains on the tractor when the backhoe is removed. It is this bracket that had interference issues with mid-mount mowers.
I heard a rumor a few years back that they were redesigning the subframes but never heard anything else about it.
Are you saying that when the backhoe subframe is removed, there is no additional bracket remaining on the tractor?
For what it's worth, I have a separate pump on my system. I think I can usually get the pump on or off faster than I could connect quick connects.
~Rick
   / backhoe #13
Rick Jay,
</font><font color="blue" class="small">( What year . . . )</font> Mine were bought January '04.
</font><font color="blue" class="small">( Are you saying that when the backhoe subframe is removed, there is no additional bracket remaining on the tractor? )</font> Yes. I'll try to get some photos and post them the next time the backhoe goes on.
   / backhoe #14
aloha,
Thanks for the response. A pic would be great! No rush, as I'm happy with my set-up and the bracket's interference with a mid-mount mower wasn't an issue for me as I didn't need a mower.
Still, it sounds like Woods made an improvement to the way the sub-frame attaches to the tractor.
Thanks again,
~Rick
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
Kubota K7874 18in Digging Tooth Bucket Excavator Attachment (A55973)
Kubota K7874 18in...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
JOHN DEERE 915 V-RIPPER (A52708)
JOHN DEERE 915...
