JC-jetro
Elite Member
That will feel like a heavy tail on your tractor. I had one on a similar size old Massey and it planted the rear nicely for snow plowing. I did set it up so the weight was borne by the frame mount for the backhoe so the 3-point wasn't holding it up all the time and would recommend that. Lets see it finished!
Jim
3 point on kubota picks up 2800 lbs. All I wanted is some sensible weight only when I need to lift and do some loader work. I don't have backhoe mount so it has to hang from 3 point. The tractor has sub mount so the weight is distributed well from the rear axle to transmission. I guess my question is 1200-1400 lbs adequate. Don't want to put too much or not enough. The finished product will be done next year when we build. I would have a 2x2x2 plywood box( form) ready with the lift arm mounted inside with the pin sticking out. They always have excess concrete after the pour and I'll ask them to dump it i to the box. It will happen next spring. Need one sheet of osb plywood and some scrap 2x4 for stiffening it. It'll just be used when needed. I can also put the carry all or my dirt scoop with some big heavy rock but I wanted it to be solid and not slide off.
JC,
