#$%@&*! Barbed Wire
/ #$%@&*! Barbed Wire #1
TonyC
Platinum Member
Monroe, Va
Kubota 1997 L3600DT 4WD with FEL
Okay, the only purpose of this post is to vent! Bush-hogging on the back nine yesterday and ran over a two foot piece of ancient barbed wire. Now my baby is sleeping outside (lions and tigers and bears, oh my!) with a rear tire flat as a pancake. All of my precious and expensive fluid laying in a puddle. I've never lost a rear tire before and I now realize what a complicated, painful and expensive problem it presents. I can't even get a truck down there safely. This is going to be fun.
/ #$%@&*! Barbed Wire #2
It sounds like you're too late... but next time with a puncture on a "filled tire"... leave the tire hole in the "up" position so it won't drain out...
Now depending whether you have a tube or not...
If NO TUBE...Great, just plug the tire in the field and pump it back up with a cheapy 12vdc $8. air compressor and you're on your way...
If you have a tube {filled...probably, but maybe not}, I'd still try a tire plug... fill it and try to cripple it home...
How thin are those tires?... barbed wire usually justs cuts the tire...normally not puncture... /w3tcompact/icons/crazy.gif
Thanks for the tips, John. Unfortunately the tire does have a tube in it. I found someone with a portable compressor and got it filled up enough to limp it home. The tires are stock Kubota...what I have is a tiny pinhole in the sidewall which evidently made it to the tube. What made it worse is that the air and fluid got between the tube and the inside of the tire...most everything leaked out around the valve stem and not the tiny pinhole. With the help of my neighbors I could probably save some money and take it in, but I'm just going to have someone come out and do it here. At least now they can get to it! Thanks again.
/ #$%@&*! Barbed Wire #4
Tony,
We hear you and understsand...kinda like when mowing a field hitting something real solid...ouch.../w3tcompact/icons/crazy.gif
Kinda strange in a way..its not so much of the cost that bothers,its the down time of the equipment. [sad]
Thomas..NH /w3tcompact/icons/wink.gif
Yep...you got it. I had planned on a lot of seat time this weekend but no luck. I just had them come out and repair the tire...$95.00, so the cost is pretty painful too! Thanks for the support.
/ #$%@&*! Barbed Wire #6
Prices must be a little higher in your area than mine; it only costs my neighbor $75 each time./w3tcompact/icons/laugh.gif And that's why I have to do my own./w3tcompact/icons/wink.gif
/ #$%@&*! Barbed Wire #7
hey bird do you install calcium in them yourself also? and if so how. i am gona be in the market for a couple new tires in the future and trying to find the best and cheapest way to do it. thanks
/ #$%@&*! Barbed Wire #8
bky, I don't even know where you could get any calcium in my part of the country. I've even had neighbors tell me they thought it was illegal to put in tractor tires in Texas. The neighbor I mentioned had calcium in the tires on his Oliver because it was about 25 years old when he bought it, it came from Minnesota, and he didn't know it had loaded tires until he had the first flat. He has since had to replace both rusted out rear wheels and doesn't have the tires loaded anymore. I have water and antifreeze in my tires and installed it with my own homemade gadget shown in the attached photo (some tractor stores sell similar ones).
/ #$%@&*! Barbed Wire #9
Some people around here tube their tires, then fill them with windsheild washer fluid, which can be bought in 55gal drums. Has anyone tried that?
<font color=green> MossRoad </font color=green>
/ #$%@&*! Barbed Wire #10
Currently, I am looking for a source locally to buy the 55 gallon drums. I need 3 drums... and considering without tubes...
I have/had Calcium Chloride in a number of other tractors... I've never had any problem as other people have stated, but I think the time has come to advance...
At this time, the windshield washer fluid appears to be the most economical and cleanest way to go... the only thing I'm concerned with now is the longevity of it chemically... will it end up losing/diminish it's "anti-freeze" properties 5-7-10 years down the road...?
{I know Cal Chloride doesn't...}
/ #$%@&*! Barbed Wire #11
TonyC,
When you started about barb wire and brush-hogging, I figured you were going to reference winching the stuff up. When a brush hog gets a hitch on some good wire, barb or otherwise, it can make an incredibly high speed winch. Many feet can instantly become wrapped around, above, betwixt, etc. the stump jumper. Makes on heck of a mess. If it won't unwind (yeah, right), only way to get it out is with a torch, and that can be hard on the gear box seals. Been there. Ya want to be real careful around wire and a bush-hog.
Nick
Farmer kid usetabe, Farmer Wannabe
/ #$%@&*! Barbed Wire #12
I have used an orbiting grinder to remove barbed wire from bush hog.
I actually had two choices...the other choice was cheaper, probably around $75.00. They couldn't come out for a week, though. The expensive guys came out right away. I guess we pay for impatience!
MossRoad...when they drained the fluid from my tire I noticed it was blue. The guy told me that it was exactly the same stuff that's used in windshield washers, just a bit more concentrated. I guess it works!
/ #$%@&*! Barbed Wire #15
Sounds like the choice our horse vet gave us when we had to have a horse put down this past summer. /w3tcompact/icons/frown.gif She said she worked with 2 places that would dispose of the remains.
One costs $150 and will be there within an hour or two after she put the horse down. The other cost only $75 but sometimes would take a few days to arrive. We paid the extra $75!
Sorry to hear about your horse. My neighbor raises horses and when they go down it hurts the pocketbook as well as the heart. In your case, you had a good excuse to be impatient. That's not the kind of thing you want to drag your feet on.
/ #$%@&*! Barbed Wire #17
John, Somewhere I read a post on folks using concentrated beet juice to fill their tires. I gues the high sugar content keeps it from freezing and it's all natural. Windshield washer fluid and antifreeze are toxic. CaCl is caustic, but fairly harmless to the environment and nothing will drink it. Wish I knew about the beet juice 3 yrs ago. I believe the post was on the compact tractor board site. http://jplan.com/cgi-bin/tractor/testTractor.pl
/ #$%@&*! Barbed Wire #18
A friends wifes dad was killed by barbed wire while shredding. It seems the wire wrapped up and the end spun around and pierced his heart.
/ #$%@&*! Barbed Wire #19
The suger beet juice around here is sold by the trade name Rimguard...
<font color=blue>...toxic...</font color=blue>
My wife has a number of household cleaners under our sink that are deadly toxic... but that doesn't prevent us from buying or using them for their intended purpose... /w3tcompact/icons/wink.gif
At this point, I feel the windshield washer fluid offers the most bang for the buck and one of the "cleanest" as compared to what else is currently available...
/ #$%@&*! Barbed Wire #20
I heard mention of Rimgaurd. Sounds worth looking into.
My loader has calcium in the tires. I noticed that it was wet around the tire in the garage, so I followed it up to the valve stem. It had rotted out. I had to jack up the tractor and rotate the tire so the stem was at the top until I can get it replaced.
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
Utility Cart (A59231)
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2018 Sea Pro Boat with 14ft. S/A Magic Tilt Boat Trailer (A59231)
2018 Sea Pro Boat...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
