Barn under way (not under roof!)
   / Barn under way (not under roof!)
Finally! The initial construction phases are complete! Now I can relax and enjoy some hunting and get this baby enclosed and finished at my leisure.
   / Barn under way (not under roof!) #23
Nice job. I really like your soffit job!!!
Eddie
   / Barn under way (not under roof!) #25
Wow. Really nice job on the roofing/soffits/gutters. Isn't some of that going to be a pain in the butt to work around when you try to side and finish out the barn though?
No Deezler, should be a piece of cake. I have J-Channel installed already all the way around the top.
   / Barn under way (not under roof!) #27
I saw that, but meant more like where you have the downspouts coming down the posts, but I guess that's easy to r & r.
What color siding are you going with? I like the dark roof.
I put the downspouts together with screws so they will be easy to disasemble. I have plans to capture the rain run-off into a 300 gal. poly tank and then gravity drain into an old U/G sistern located nearby since this is way back in the woods with no water available, but that is a project for next spring.
Siding will be a light beige color. Three of the "bays" will remain open and the fourth will have a wall installed to separate from the rest and a sliding door mounted on a rail.
Thanks,
Dave
UNUSED Mini Excavator Rake Attachment (A47477)
UNUSED Mini...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2003 Chevy 2500 Pickup (RUNS) (TITLE) (A50775)
2003 Chevy 2500...
Set of 4 ST225/75R15 Radial Trailer Tires (A55787)
Set of 4...
2016 Sure-Trac 20 Tone Tag Trailer (A54865)
2016 Sure-Trac 20...
Heavy Duty Jumper Cables (A55788)
Heavy Duty Jumper...
