Basement Windows
   / Basement Windows
Before any cutting, we drilled and placed some lag bolts. Here, Mark is bolting on a chain to move the slab. Due to the wall thickness, there was no danger of it falling on it's own so we pulled on the top while another neighbor pryed from the inside to wiggle it out. Of course, what does one do with a 4X4X8" piece of concrete? It does need to be considered /forums/images/graemlins/smile.gif
   / Basement Windows
And finally, daylight shines in the basement. We let the slab fall onto a couple of timbers to aid in pulling it out. I knew my tractor wouldn't lift it but we thought we'd try an angled pull up a ramp of sorts. After putting more air in my front tires all was well. Should have pulled from the rear but with the backhoe on the attach points are limited. We used the hook on my bucket and all was well /forums/images/graemlins/smile.gif
   / Basement Windows
Mark now has an interesting lawn ornament. I suggested burying it but he has another buddy with a conventional concrete saw. That will be a breeze with it laying on the ground. He'll cut it in quarters and haul it to the local concrete recycling yard. I do believe this was the heaviest load I've had on my FEL /forums/images/graemlins/smile.gif
   / Basement Windows
The day is wearing on... which means fewer pictures taken.
While Mark made the cuts on this window, I dug the second one. No pictures but it was much more of a surgical dig with sprinkler lines and a gas line. I tagged one sprinkler line but never got close to the gas line thankfully. I also moved a lot of dirt to a back corner of his lot for a landscape island. He has plenty more dirt to deal with.
Once we got the slab out we lowered a section of retaining wall that he pre-fabbed. Had to use the backhoe as a crane but didn't get any pics. Here it is in place /forums/images/graemlins/smile.gif
   / Basement Windows
The rest of the wall was built up one layer at a time. Mark pre-built the sides/back so it went pretty fast. The wall opposite the window has three steps that meet egress code as well as let in a lot of light. Here's a well deserved break /forums/images/graemlins/smile.gif
   / Basement Windows
And that's it for today. We got the window framed with treated lumber and set the window unit. What we thought would only take a half day turned into a full day project but the second one should go faster. The only tractor work left on the second one is getting the slab out and maybe some backfill work. Couldn't think of a more fun way to spend a nice fall day /forums/images/graemlins/smile.gif
   / Basement Windows #18
That project was very impressive, to say the least. Very glad to see it move with no major hitches, and having the right tools certainly does pay off.
Also can tell there was some good, experienced planning that went into this project.
Thanks for the pictures.
One comment, you said it 'couldn't fall in' and I didn't catch 'why'. Superman was inside? /forums/images/graemlins/wink.gif
   / Basement Windows #19
Question on the concrete saw. How does it deal with the re-bar in the wall?
I have two doorways I would like to cut in my basement wall.
If I get serious, maybe I should PM you and ask about buying that slightly used saw from your buddy :).
- Rick
   / Basement Windows
<font color="blue"> One comment, you said it 'couldn't fall in' and I didn't catch 'why'. Superman was inside? </font>
No Superman, just simple geometry. First, you have to understand that Mark and I work together and are both engineers. Geeks, if you will.
Then the math takes over. The wall was eight inches thick and the saw kerf was only 1/4 inch. The shear weight of the slab (had to be over 1000 lbs) prevented it from sliding straight out on it's own. The thin kerf and thick wall prevented it from tipping. The edge hit long before it tipped out. To get it out it had to be pryed from inside along the bottom. We just kept some tension on the top via the chain to direct it's fall onto our timbers.
A bit like a cork in a wine bottle. You can't tip it out, you have to pull it straight /forums/images/graemlins/smile.gif
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2015 Chevrolet Tahoe SUV (A59231)
2015 Chevrolet...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1992 AM General...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
