John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,601
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
Years ago I had a mechanical shop and it wasn't unusual to have 20 batteries all needing attention. Usually they were lucky to get trickle charged if I remembered to move the home-made trickle charger from one to another. My experience is about like yours.... trickle charging is good because if the battery is good it keeps it from going flat when it isn't being used. So you have battery when you need it. But I can't say that trickle charging did anything to help an older sufated battery. I always hoped it would, but it never seemed to improve an old battery. It did keep good ones at full charge though and that was worth doing.
Keeping a battery charged is a good way to avoid forming sulfates - that happens in a discharged or partially discharged battery. However, a simple trickle charger will not undo sulfation that has already formed in the battery. You need a charger with the desulfation feature for that.
So I think the answer to where the CTEC fits in is that trickle charging is one of the things that the Battery Minder does. But the Battery Minder seems to do more than that. Along with whatever it does for sufated batteries, the Battery Minder has a high amp mode for charging fully flat batteries. On high amp mode it monitors what's happening somehow so that it doesn't overcharge and then turns itself into trickle mode at the end. It has some dash lights to let you know what mode it's in.
The BatteryMINDer desulfates a battery by sending a high-frequency pulse through the battery every few seconds. I'm not sure HOW it accomplishes it, but that pulse works to break up the sulfation. BatteryMINDer chargers perform desulfation continuously, both during charging and during "float" operations. Being a smart charger, it monitors the battery condition, and will not overcharge (overcharging is a problem with some "dumb" chargers).
Some other desulfating chargers us a high-voltage pulse to accomplish the same thing. The pulse is brief enough that the high voltage does not damage the battery, but it does break up the sulfation. I have no idea if one method is better than the other. "Battery Tender" brand chargers do not do desulfation (which is why I do not use them). Most (maybe all) NOCO chargers do desulfation with the high-voltage pulses, however, they do this only while the charger is in charging mode, not while they charger is in float/maintenance mode.
I don't know exactly why the Battery Minder is good, and I've no stake in the company. It works for me.
rScotty
I've also had very good luck with the BatteryMinder chargers. (I own at least 5 of them, one of which is approaching 20 years old.) I also own a Noco Gen2 charger. I've not owned it for long, but it appears to be working well also. I'm not a fan of the Battery Tender or Harbor Freight brands of chargers. Battery Tender works OK if used regularly, but will NOT recover a sulfated battery. The Harbor Freight chargers I just can't bring myself to trust.
