Bearing removal
   / Bearing removal #51
My uncle redid the spindles on a small catapillar
and he used nickel silver welding rods to build
them up and then ground them to spec's
I used silfos to solder a/c copper fittings and I
didn't have any solder so used silfos to solder
some heavy copper wires and had a piece that
was sticking out and I could not cut it off with
wire cutters had to grind it off, it sure went up in
price $4 a stick and higher???
willy
   / Bearing removal
Making any headway?
Well got axle out ring gear got couple chips..branson say two diff ring gears..one with dowl pin one without...they dont seem to know which one i have. so going tear down axle..and determine..one i will need new diff..other i dont....tractor be death of me Thank u
   / Bearing removal #53
Stay with it. You will get there.
   / Bearing removal
Well took two months but i got it done..new pinion and ring installed..no leaks..Wish to thank All that assisted me..thank u All
   / Bearing removal #55
Great Job! Glad you got it done!
   / Bearing removal
Question..how do u keep diff lock in...im plowing snow thats its manual shift trans with clutch.
   / Bearing removal #57
You have to hold the lever down with your foot.
   / Bearing removal
Well thats crazy how u suppose hold down and press clutch..🤣 but tks for reply
   / Bearing removal #59
You press it with your right heel. Isn't the clutch pedal on the left and the diff lock on the right on your tractor?
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
Case IH Farmall 105C Tractor (A50514)
Case IH Farmall...
Cat 277 Skidloader (SALVAGE) (A50774)
Cat 277 Skidloader...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2015 INTERNATIONAL...
2008 Ford F-250 (A52748)
2008 Ford F-250...
Kubota SVL95-2s (A50120)
Kubota SVL95-2s...
