Bees in covered split wood stack.
   / Bees in covered split wood stack. #11
Get in touch with the local beekeeper's club. They wil usually come and take the hive out for free.
Wouldn't that be true only for honey bees? I'm not sure that's what they are.
Cliff
   / Bees in covered split wood stack. #13
Beesource.com has a trapout section you might find someone to get them.
   / Bees in covered split wood stack. #15
I have heard of guys using a large shop vac. May need to do it a couple times and pull apart pile to get queen.
   / Bees in covered split wood stack. #16
Are they being a nuisance? Is this building close to the house or an area where you might get stung? Why not just let them be?
Bees are inactive in the cold winter months. When you are out there collecting fire wood, they will be dormant and sluggish and unable to do any harm, you could take the nest apart then.
I know it's human nature to want to control everything 100% of the time, but if they really aren't hurting anything, why mess with it?
   / Bees in covered split wood stack. #17
Just pick away at the pile a few bits at a time over a week or two and until you uncover the hive (use a long rake or do it when it is cold). Keep picking away and they'll eventually decide it's a crummy place to live and move on. Done this a couple of times.
They close to the back door of my house and in the lawn where I need to mow, so I don't think I can leave them be. I've found that bees don't like lawnmowers (especially when you run the lawnmower over the hive in the ground -- which is another story)
Cliff
Could you tarp off the front and use an insect fogger?
MarkV
You know, that might be the simplest solution. I'm not fond of using poisons, nor am I fond of leaving a poisonous residue on the logs I will burn, but I might be able to get by with a small amount. It shouldn't take much fog in such a small enclosed area.
Cliff
I'd do this if it wasn't near my back door. They might also move somewhere more worrisome, like the tractor seat - ouch.
Cliff
Tractor (A59228)
Tractor (A59228)
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2018 Deere 323E (A53317)
2018 Deere 323E...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
