Bent Digging Edge Of B7510 Bucket?
   / Bent Digging Edge Of B7510 Bucket?
Any special typeof steel? Special rod required for welding it on? How about MIG?
   / Bent Digging Edge Of B7510 Bucket? #12
Robertm,
Are you going to get a new bucket? It sounded like you were thinking about it from your original post.
Nah, the "wowee" is just a dip in the cutting edge that I can beat back into place with a sledge hammer (probably a 2-pound hammer is more like it), but I just do not want to re-live the experience. The bend is not really a big deal, it's just that when I scrape the asphalt driveway off, I don't want to scuff it with the dip in the cutting edge. I am contemplating getting a welder soon, and I would like to reinforce the cutting edge, and add some hooks, so this looks like a god project to tackle. Does anybody have some input on where I should locate the new cutting edge to weld on? Under the existing one I assume. What about the new exposed edge of 1/4 or 1/2 plate (bar). That certaily won't help cutting into soil, or am I missing something here?
   / Bent Digging Edge Of B7510 Bucket? #14
Robertm
PM Henro . He's got a tooth bar that's very well designed .
The entire cutting edge of it fits over the buckets existing cutting edge . The teeth are then welded to that .
Sorry if the explanation was poor ,and that I don't know the maker of it . But I'm sure Bill ( henro) will help you out with a good description and maybe a PIC or two of it .
The only reson I didn't get one myself was that I wasn't aware of them until AFTER I alredy had a tooth bar of a different make /forums/images/graemlins/frown.gif John
   / Bent Digging Edge Of B7510 Bucket? #15
You cut the old cutting edge of with a torch and then weld on the new one.
Egon
Oh !@#$%&! Now I'v got to add TORCHES to my wish list, too? /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
   / Bent Digging Edge Of B7510 Bucket? #17
The cutting edge on my 60" B2710 bucket is totally worn. I just put a tooth bar over it. Solved that problem for now.
However, had I wanted to change it, my dealer had generic weld-on cutting edge in stock for just over $1.50 per inch (ouch). All I would have to do is grind off the existing weld, remove the worn cutting edge, then weld in the new edge. I choose the tooth bar route.
   / Bent Digging Edge Of B7510 Bucket? #19
Good idea. I can get some good used grader blades every once in a while. The ones we use are approx. 6" wide. Did you cut the bucket or place it over or under. Post a picture if you can. Thanks
   / Bent Digging Edge Of B7510 Bucket? #20
I learned my lesson with Kubota buckets quite a while ago. The material buckets bend at the cutting edge. The last one I had on my 3710 had a hay spear in it most of the time. I broke it numerous times at the left hand edge between the cutting edge and the bucket side. It also had a "smile" in it
Kubota offers "material" buckets and heavy duty "round back excavation" buckets. This time I have the heavy bucket. It's actually a double wall bucket and it doesn't bend. Besides, the cutting edge is high carbon steel. The round back is more money but it's a better bucket by far than the light gage material bucket.
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
