Snow Equipment Buying/Pricing Best Chains for 12.4 24 Agri Tires
   / Best Chains for 12.4 24 Agri Tires
The Super Chains appear to be what I am looking for but they do not have chains for my 12.4 24 size unfortunately.
   / Best Chains for 12.4 24 Agri Tires #12
Order the chains for front and rear from Pewag and they wil have them to you shortly.
Your metric size should also be on the sidewall of the tires as well.
Pewag USA has these model chains for your rear ag tires
Square tractor #E0852
Twist #H0852
Square Dou "H" #H22SL
What is the size for the front Ag tires on your tractor?
   / Best Chains for 12.4 24 Agri Tires #13
Don't get straight "ladder chains" on ag tires(R1's)!
Get the chains that have links binding the two cross links togther and if you have icy conditions, get the same pattern with the welded lugs on them. The problem with ladder chains is that slip between the lugs and are useless. Don't forget to use chain tighteners also.
Nope. This is an urban legend. I have 4 link ladder chains on my ag tires. They have made a world of difference traction wise. The key to using ladder chains on ag tires is to not use tensioners. Left a bit loose, the chains are the first thing to make ground contact. They are the best value for tractors so I do not think they should be eliminated from consideration. I like them lots better than the chains alledged to be designed specifically for ag tires (your description) called "duo chains" as there is not anywhere near the spacing between cross links compared to ladder chains especially the two link type.
   / Best Chains for 12.4 24 Agri Tires #14
If you can properly install tire chains, tensioners are not needed. Tire chain tensioners in ALMOST every instance are a money-maker for folks selling chains and a crutch for those that don't know how to use them.
+1 Rick
   / Best Chains for 12.4 24 Agri Tires #15
Thank you all for your advice and feed back! I will check out the links and get something on order ASAP!
Should I worry about putting them on the front tires (I have to use 4WD here due to the terrain...no flat roads/drives in sight) if I get the ones with the aggressive nubs on the back?
You probably won't need fronts for pulling power, but I find the tractor tries to walk sideways while plowing heavy snow with the rear blade angled. Your tractor is heavier than mine so you might not have the same problem.
One school of thought advises against using chains on the front due to added stress on the front drive train. I really don't have an opinion on that.
Sean
I have 7-16 tires on the front
Definitely have the problem with walking sideways with the rear blade angled...if I need the front tire chains as well I will get them.
   / Best Chains for 12.4 24 Agri Tires #18
The Pewag chains for the 700 -16
tires are the following:
XMR80
ASV 79
Be sure to explain to the Pewag folks
that these chains are intended for R1 Ag tires
if you place an order with Pewag Inc.
My other question to you is this;
Are your rear tires ballasted with liquid
or cast wheel weights?
My second question is this; Are your rear wheels
installed with cast steel rims or are they constructed of
rolled steel?, if they are constructed of rolled steel the rim
interior will have ridges from the rolling press which indicates
they are a rolled steel rim base and therefore of weaker
construction and will flat spot and create situation referred to as
"The Hoppsies" at travel speeds.
Sorry I was off line for a few days (had to go back to real job!)
My front tires are 7-16
Case-IH 370 Steiger (A50120)
Case-IH 370...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
John Deere Z994R (A50121)
John Deere Z994R...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
Massey Ferguson RB 4180V Round Baler (A50774)
Massey Ferguson RB...
2010 Honda Accord Sedan (A50324)
2010 Honda Accord...
