Best commercial zero turn?
Status
Not open for further replies.
   / Best commercial zero turn? #201
The old Deines is an 1800, 60 inch. Kohler Magnum 18. May have to look at possibly rebuilding the hydro if possible, to sell it. Runs great, just a tad hard on the body now as I get older. They really haven't changed much over the years.
I will be cutting this aft with the Toro, will post results.
I hear you - the single small back wheel with no suspension can be a little rough. I bought one with the spread two wheels in the back - makes a world of difference.
   / Best commercial zero turn? #202
That's a first that I heard of a Kawi sucking gas down. What are you comparing to?
Just a blind observation...I've nothing to fairly compare it to beyond decent guesses. I've got a 7hp gas splitter and a 30hp diesel that can run maybe a half gallon an hour. The 24hp gas mower gets around a quarter of that...or so. No good studies...just approximations.
   / Best commercial zero turn? #203
WOW I am impressed. More responsive than I'm used to. I do bottom out occasionally with the ride system, not a fault of the machine, but me being a tad over 300 lbs. Should take more than an hr off my regular cutting time without the old bump and grind. My body will thank me many times over. More to come after a full mowing session.
   / Best commercial zero turn? #204
I have a 35 HP Kawasaki (fx1000v) on my zero turn with 72" deck.
I like the engine, very smooth with good power. But great on fuel its not. When pushing it hard I'm probably nearing 2 gallon per hour.
   / Best commercial zero turn? #205
Completely agree....love the Kaw on my Yazoo, reliable, powerful, but thirsty. Easily my favorite of the twin cylinder commercial gas engines.
   / Best commercial zero turn? #206
Moved the seat forward some to keep the weight off the rear to adjust the weight bias. Reduced the bottoming out to minimal. Happy happy. Learning. Should read the manual.
   / Best commercial zero turn? #207
John Deere diesels have been the best, Xmark rear and side discharge have been less reliable mainly parts wearing out, engine has been ok.
The mowers I'm talking about are put through some of the worst conditions with contractors running them. Deere gets the top shelf. PERIOD.
   / Best commercial zero turn? #208
The heading is for commercial zt. I was responding the MyRide post. Hope it's still relevant. The Titan with My Ride is a winner. Anyone contemplating a new ZT should experience the system. 2.1 hrs doesn't make me an expert, but after using the old Deines for several years, no suspension or even a sprung seat, I feel confident in recommending this one. For those who have done the dirt bike thing, it's like going from a '70's trail bike to a monoshock motocross bike.
On a side note, the hydro on the Deines is ok, just a way too quick diagnosis with the symptoms I noticed. Merely the intermediate sprocket shaft/ chain adjuster had shifted, causing the chain to skip on the small cog. It's all good, wanted a new mower anyway.
   / Best commercial zero turn? #209
That is what I find with the Deines - they are very simple and just do not quit. And also have a very nice cut.
   / Best commercial zero turn? #210
I will miss the ease of cleaning the underside of the deck and being able to cut under trees and shrubs. For cleaning and sharpening this one, the fel will come into play.
Status
LOT LOCATIONS (A52576)
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2011 FORD F-450 (A52472)
2011 FORD F-450...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
