Best engine oil weight?
   / Best engine oil weight? #11
Yep the average auto parts store might not carry a C rated 5w30. So shop at an above average store like an on-line store maybe? AMSOIL DHD 5w30 is available and currently they have a promotion with FREE shipping. A top notch oil delivered right to your doorstep....Dutchy
Diesel Engine Oil: Shop Engine Oil for Diesel Engines - AMSOIL
   / Best engine oil weight? #12
Whatever. Go to an average auto parts store, Sams Club, Costco or Walmart and see how many C rated 5w-30 oils you find. The OP isn't seeing it either.
It's out there, maybe not in all regions, so online may be the best option.
Shell Rotella T6 Multi-Vehicle 5W-3? Full Synthetic Diesel Engine Oil, 1 Gallon - Walmart.com - Walmart.com
not 5W-30 but 5W-40 (some would consider even better)
Shell Rotella T6 5W-4 Synthetic Heavy-Duty Diesel Engine Oil, (3-pack/1 gallon bottles) - Sam'''s Club
   / Best engine oil weight? #13
Same question, different day:
What is the ONE grease I can use for all of my greasing needs.
What is the ONE OIL that will work.
Answer:
Your equipment was designed by precision engineering.
The lubricants were a part of that.
If you care about maintaining your equipment for many decades of operation you will follow the MFG recommendations.
There is NOBODY here that can give you better advice than them.
   / Best engine oil weight? #14
I need to change the engine oil in my 790. I see the recommendations in the manual, with 5w-30 covering the biggest temp range, however I cannot find that weight anywhere.
I mostly use the tractor to plow snow so cold starts matter more--we sometimes have periods of -10F, but it does get over 85 degrees here too and I'd like the protection there if I need it.
Can I use 0w-40?
Thanks,
Carl
Here's a source for M1 0w30 ESP: Exxon Mobil 1 ESP X1 W-3 | SCL Only about $32 for 6 qts.
Ralph
   / Best engine oil weight? #15
   / Best engine oil weight? #17
Carl,
Tractor Supply regularly carries Rotella T6 which I have had, like many others, very good experience with.
Maybe not 5W-30, or 0W-40; most diesel oils are 15/40 with 5W/40 as an option for colder climates.
https://www.tractorsupply.com/tsc/p...l-synthetic-5w-40-heavy-duty-motor-oil-25-gal
I don't think you could go wrong with this oil
Been running 5W-40 Shell T6 in my L39 TLB Kubota with just under 2,500 hours. After 164 hours I got around to changing the oil finally. I went with 5 Qt Jug of 0W-40 Shell T6 & 3 quarts 5W-40 Shell T6. All is good, especially for the winter.
Motor will probably outlast me.
I expect my now sold old B7200 of then 32 years motor with 3,000 hours could run for another 30 years. 50 hour oil changes are a waste of time.
   / Best engine oil weight? #18
Well I was looking for the Torq-Gard brand. I should have mentioned that. If I can just use a high-quality other brand, then I guess I'm good!
Torq-Gurd is John Deere's house brand of oil. It should be available at any JD dealer or online.
   / Best engine oil weight? #19
NAPA & O'Reillys - each have half a dozen brands with 5W-30 oil.
   / Best engine oil weight? #20
Everyone has their OWN idea about what oil and weight is best, and to be honest, ALL of them will work just fine, IF you keep it changed like you are suppose to.
This is what I put in my loader tractor yesterday,
It's the first time I've ever used that brand, and the first time I've ever put synthetic oil in that tractor.
SR
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
JOHN DEERE 2350 TRACTOR (A54756)
JOHN DEERE 2350...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
