Best Gloves???
   / Best Gloves??? #1
dillo99
Upstate NY
Kubota B7500
This might sound like a bland topic but what do you think are the best work gloves. I go through them like there is no tomorrow and I can't seem to find a pair that will last. I think I like the IRONCLADS the best but even they don't stand up to a day of my chipper.
What are your thoughts??
   / Best Gloves??? #2
"think I like the IRONCLADS the best but even they don't stand up to a day of my chipper."
You know.. you should NOT be putting gloves THRU the chipper to test them.. I doubt there is any glove that will stand that.. LOL
All joking aside.. If you are going thru gloves that fast I hope someone else can chime in and make some suggestions..
Brian
   / Best Gloves??? #3
I have yet to find a good leather work glove that lasts.
but for a great insulated grip glove try an atlas thermafit, Im amazed at how long the last. but barbed wire will take them out in a day.
Perfect Fit Glove
   / Best Gloves??? #5
I've been pulling massive blackberry bushes out of orchard trees that were abandoned to the blackberries years ago.
HF's roping gloves are thick enough to stop the blackberry thorns yet soft enough to still flex like a second skin. I like them better than heavier gloves. My present pair has stood up to some 50-100 hours of this use. (Don't confuse these with their similar, lighter Driving Gloves).
I tried HF's cheap cotton back gloves (6 pr/$5) and the first pair didn't last a day in that application. They were shredded, and several thorns came through.
   / Best Gloves??? #6
Try some horsehide gloves from gemplers, They are super tough. Or try some pigskin they are tough and extremely flexible and have the advantage of fitting better and stay on if you wet them and wear until dry. They do not harden after getting wet like cowhide, they form fit to you hand.
Jeff
   / Best Gloves??? #7
The gloves I like the best are sold by Stihl dealers for 15.95. Less money than the other lesser quality gloves I used to use.
Andy
   / Best Gloves??? #9
I recently bought a couple pair of DTPro kevlar reinforced gloves from Duluth Trading. They have been great. I've been demoing some old poultry houses and handling a lot of cut metal as well as rocks, concrete, wood, etc.
I like 'em.
   / Best Gloves??? #11
I get the Wells Lemont heavy duty leather gloves at our Farm & Fleet. They last very well for me. I even pick up burning logs and throw them back into the fire.
   / Best Gloves???
I knew I was doing something wrong.
Thanks everyone for the ideas. Maybe I will order a bunch of different ones and do a review after running them all thru the chipper! I'll definitely have to take pictures.
   / Best Gloves??? #13
Mike and Brian:
I read your comments on what are the most durable work gloves. I highly recommend any of the Dickies Goatskin gloves or Any goatskin glove sold under the ACE Hardware brand in their stores.
I am the manufacturer and have independantly lab tested the leather vs. cow and pig which is the predominant leather used in work gloves. We have a proprietary process of how we tan our goatskin which makes it significantly more durable than any other leather with the exception of elk. Goatskin is slightly thinner which improves dexterity. Lastly, you can also wash goatskin leather gloves but make sure to air dry. They will be a little stiff at first but will soften up after a few minutes of wear. Hope this helps?
Regards,
Ayrshireman
   / Best Gloves??? #15
I have no idea who makes them since they are branded with the stores name but I get my double palm leather gloves from Gebos which is a Texas based farm store, I use these when I go after green briar, Mesquite or anything else that requires ruggedness.
Try several, I went through several before I found these and they are 16.00 a pair.
Goatskin is great for dexterity..... not thorns.
   / Best Gloves??? #16
I found out the make & brand, Cordova Elkskin work gloves style 97101. I can't seem to find them online and I haven't had to purchase any in a few years since I bought several pairs to last me.
I used these when I was clearing my property, I did go through several before finding these.
Good luck and when you do find some that work..... buy a case.
   / Best Gloves??? #17
A few years ago I was given a pair of these for Christmas, Wells Lamont - Style 1060 Heavy Duty Cowhide Leather Gloves, and there the best gloves I have used. There lined for winter use and in the summer the lining doubles as cushioning to protect your fingers. They also work real well in protecting my hands from the barbs on the steel cable that I use to pull out trees. I ended up loosing the original pair after I left them on the fender of the trailer, but I have since bought two more pair so that I have spare's on hand.
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2010 VOLVO A30E OFF ROAD DUMP TRUCK (A60429)
2010 VOLVO A30E...
Mini skid steer auger attachment (A59228)
Mini skid steer...
