Best Kubota for 25 acres
   / Best Kubota for 25 acres #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Which Kubota is the best for 25 acres. Looking for bh & fel, 4wd. Putting in drive, keep up trails through woods, culverts, drainage ditches, planting trees, working ground around house. I have similar post in general section, but now looking for brand specific info about Kubota's. I looked at the L39. I am thinking in the range of a 40hp tractor, nimble, but tough enough for hard tasks. If you can even give me models to consider, I will check them out at dealer. Thanks.
   / Best Kubota for 25 acres #2
You might want to look at the L3830HST & L4330HST. They are compact utility tractors with the ability to remove FEL and change attachments easily. A BH90 will fit either one. They also come with skid steer type FEL. A fellow TBNer (_RaT_) sold his L48 to get a L3830. Here is recent thread on the L3830. Click Here
   / Best Kubota for 25 acres #3
I just purchased a L5030 with BH, FEL with QA, lots of attachments to do the very same thing. I went with the R4 tires and HST. Best thing I did, it works great.. Add the Top & Tilt Option, it's a must. Don't forget the front remotes for the FEL, this will allow you to use a grapple....
Good luck....
Horse Power RULES !!!!!!!!!!!!!!!!!!!!!!!!!
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
30 Yard Roll Off Container (A51573)
30 Yard Roll Off...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2006 CATERPILLAR 252B SKID STEER (A51246)
2006 CATERPILLAR...
