Best Kubota for 25 acres
   / Best Kubota for 25 acres #1
Slippy
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Which Kubota is the best for 25 acres. Looking for bh & fel, 4wd. Putting in drive, keep up trails through woods, culverts, drainage ditches, planting trees, working ground around house. I have similar post in general section, but now looking for brand specific info about Kubota's. I looked at the L39. I am thinking in the range of a 40hp tractor, nimble, but tough enough for hard tasks. If you can even give me models to consider, I will check them out at dealer. Thanks.
   / Best Kubota for 25 acres #2
You might want to look at the L3830HST & L4330HST. They are compact utility tractors with the ability to remove FEL and change attachments easily. A BH90 will fit either one. They also come with skid steer type FEL. A fellow TBNer (_RaT_) sold his L48 to get a L3830. Here is recent thread on the L3830. Click Here
   / Best Kubota for 25 acres #3
I just purchased a L5030 with BH, FEL with QA, lots of attachments to do the very same thing. I went with the R4 tires and HST. Best thing I did, it works great.. Add the Top & Tilt Option, it's a must. Don't forget the front remotes for the FEL, this will allow you to use a grapple....
Good luck....
Horse Power RULES !!!!!!!!!!!!!!!!!!!!!!!!!
JOHN DEERE 2038R LOT IDENTIFIER 162 (A53084)
JOHN DEERE 2038R...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
1838 (A51248)
1838 (A51248)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
