Best Kubota for 25 acres
   / Best Kubota for 25 acres #1
Slippy
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Which Kubota is the best for 25 acres. Looking for bh & fel, 4wd. Putting in drive, keep up trails through woods, culverts, drainage ditches, planting trees, working ground around house. I have similar post in general section, but now looking for brand specific info about Kubota's. I looked at the L39. I am thinking in the range of a 40hp tractor, nimble, but tough enough for hard tasks. If you can even give me models to consider, I will check them out at dealer. Thanks.
   / Best Kubota for 25 acres #2
You might want to look at the L3830HST & L4330HST. They are compact utility tractors with the ability to remove FEL and change attachments easily. A BH90 will fit either one. They also come with skid steer type FEL. A fellow TBNer (_RaT_) sold his L48 to get a L3830. Here is recent thread on the L3830. Click Here
   / Best Kubota for 25 acres #3
I just purchased a L5030 with BH, FEL with QA, lots of attachments to do the very same thing. I went with the R4 tires and HST. Best thing I did, it works great.. Add the Top & Tilt Option, it's a must. Don't forget the front remotes for the FEL, this will allow you to use a grapple....
Good luck....
Horse Power RULES !!!!!!!!!!!!!!!!!!!!!!!!!
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2019 TAKEUCHI TL12V2 SKID STEER (A51246)
2019 TAKEUCHI...
