Ken45101
Elite Member
- Joined
- Feb 14, 2009
- Messages
- 3,679
- Location
- southern Ohio
- Tractor
- Kubota M5040, M9540, B21 TLB, B2710, RTV900, JD 325 Skid steer, KX-121-3 mini excavator
and many of them are equipped with a front blade, which would greatly help your needs.
ALL mini excavators have a blade, they need it for stability. The great thing about the Kubota excavators after 2006 is that they have a swing blade which is great for pushing the loose dirt off to the side.
So much depends on the steepness of the hill. If you can drive the tractor across it, a box blade or scraper blade works pretty good (except for stumps and large rocks). A dozer works better but needs an experienced op to work on really steep slopes. An excavator makes it's own level work platform before it moves forward so it can handle just about any slope.
Small, used dozers can be had for $10-20,000. But repairs are difficult and expensive. I have a friend whose dozer broke down working on a bridle trail in a state park. He had to have it towed out by a larger dozer. The belly pan covering the transmission weighs somewhere around 1000#, not something that's easy to work on
As someone said on another board, if you get a used dozer, you had best be good at doing repairs on your own. Personally, I'm not much of a mechanic.
With the economy as it is today, used construction equipment can be had at relatively low prices. You might even find leftover new equipment at nicely reduced prices.
Ken
