Best rear tire filler for cold weather
   / Best rear tire filler for cold weather #41
that is a good point soundguy. i feel kinda dumb now. i didnt even think about radiator hose. However it does seem like they do fail more that they should compaired to other cooling system parts.
heat...
again. the tire store guys are morons for saying AF makes rubber weak.
no backing out of that one.
makes all the rest of their advice suspect.
   / Best rear tire filler for cold weather #42
im still on fence between beet juice and rv antifreeze or windwasher fluid. but calcum and foam rubber is out. have to say though im surprised how well the ct225 is doing with out any liquid so far. only put about 4 hours on so far and only moving snow no dirt yet we r in a deep freeze here.
   / Best rear tire filler for cold weather #43
If you're impressed with it now, just wait until you load those tires!!! Regardless of what you decide to fill them with
Sent from my LGL35G using TractorByNet
   / Best rear tire filler for cold weather #45
Not as much suspect as clear that they don't sell antifreeze.
any time I hear someone explain something to me that is clearly incorrect. .. the 'talker' just looses all credibility with me. While it's likely he's not 100% FOS.. I usually flip that lil switch in my head and walk off. found it is easier that way. If I want to hear BS.. I can listen to politicians.
   / Best rear tire filler for cold weather #46
Still have not decided on which one to use yet. Finally had a chance to move some dirt I had my box blade on the rear also try that with my rake I don't think I'm going to need it. I think the weight of the cab helps offset it. However I don't know if my loader is lifting all that it should taking it in for its first service next week going to have them check the pressures doesn't seem like it's lifting quite what it should lift.
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
New/Unused Gold Mountain Shelter 20ft x 30ft (A51573)
New/Unused Gold...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
