Best sized NH backhoe for TC34DA
   / Best sized NH backhoe for TC34DA
Getting all my ducks in a row here. Thanks for all the help. I'll be going with the new 930 (replacement for the 758C) backhoe. I'm also having Millonzi deliver a 48" grapple to my dealer so the dealer can put on a diverter valve set up to work the grapple. Since my tractor doesn't make it back and forth to the dealer very often (80 miles each way) while it's there I'm also having them put on T-n-T. I'll see if they pick it up this coming week. After getting it back I have to remove a fairly large fallen pine that tipped over, roots and all and is sitting on top of other trees now. When I get a chance I'll post a photo in the projects section for suggestions on how to remove it. BTW, My tree makes the one currently in question there look like a twig. Scary.
   / Best sized NH backhoe for TC34DA #22
The only advantage of the 758 over the 757 is going to be reach. The 757 has more than enough digging force given the weight of the class II NH frame.
Hi Joe,
I still think that the bucket force of 1/3 less power is significant. I have also read people lamenting they got the 757 instead of the 758, but no one who has a 758 is wishing they got the 757 instead. I'd rather have extra power if needed than not enough to start with. The other thing is if I decide to sell it later I think I could sell the larger one easier than the smaller one.
   / Best sized NH backhoe for TC34DA #24
The only point I'm getting at is that unless the tractor is somehow chained down, the 757 has more than enough power to make the class II tractor dance. I dug out a lot of stumps last year with the TC33DA and 757. Although its a nice combo - it really gives one an appreciation for additional tractor weight (although a class III would have been overkill for me). The 758 should serve you well with the extra reach (something I wish I had for digging). Good luck - wish you well.
Joe
Thanks Joe for the reply. Everything you say makes sense. I was thinking the bucket strength is what is great for ripping and the boom strength which is just about equal between the 2 is what makes the tractor dance, so having that extra bucket strength would not much of a dancing difference.
   / Best sized NH backhoe for TC34DA #27
John_Mc said:
The TC45DA is a significantly larger tractor than the TC34DA. The 45 is the high end of what New Holland calls (called?) their "Class III" Compact Tractors. The TC34DA is a "Class II". The TC45DA weighs almost 40% more than a TC34DA (weight of bare tractor).
In my mind, there is no question that the 758C backhoe is a better match for the TC45DA than the 757C.
Whether the 758C or the 757C is a better match for the TC34DA is an open question in my opinion. I guess a lot depends on operator technique, and what you are digging. It does not surprise me at all that those who have this combination are happy with the BH. It's a great backhoe. You just need to be aware of the limitations of having it connected to a smaller, lighter tractor.
John Mc
Thanks for correcting me. I did not mean to give him bad information. I was thinking the TC45, TC40, and TC 34 were all the large CUT and the lower numbers went to the class II. I must be thinking of the TC35da. Thanks again for the correction. I would feel bad if someone made a bad decision based on bad information I provided.
   / Best sized NH backhoe for TC34DA #28
Yes, the TC35DA was the same frame size as the TC40/TC45. The TC34 was the successor to the TC33. Basically, they took a TC33 frame, and put the engine from a TC35 in it for a couple of extra HP.
John Mc
Hey, no worries. I already knew the 34DA was not in the same size class as the 35DA, so no sweat.
Any advantage/disadvantage of 16" (3 teeth)vs. 18" (4 teeth) HD buckets for the 758 (930) backhoe?
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2019 KUBOTA SVL95-2S SKID STEER (A52707)
2019 KUBOTA...
2022 John Deere 317G Track Loader (A53485)
2022 John Deere...
JCB 300T SKID STEER (A52707)
JCB 300T SKID...
2021 Ford F-250 Crew Cab Pickup Truck (A55852)
2021 Ford F-250...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
