Best used attachment under $500.
/ Best used attachment under $500. #1
rdinatal
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
The title should say "Most Used Attachment"
What if you had $500 and wanted to spend it on something. For arguments sake you had a (S)CUT, FEL and a rear blade (box or scrape).
What would you get and why?
-R
/ Best used attachment under $500. #2
In my case, at $500 it would be my 9' Flail mower, which I have yet to see in person. But will Friday night. Hope to try it out on Saturday. Otherwise I guess a 5' Rotary mower would be useful.
/ Best used attachment under $500. #3
What type of property and how much property do you have.
What do you do on property
Generally rotary cutter
/ Best used attachment under $500. #4
If you don't already have a drawbar they can be handy. Cost almost nothing and great for dragging and pulling posts/etc out of the ground.
/ Best used attachment under $500. #5
If I did not already have one,,, I would buy a $200 chain,,,
for that much, it is unbreakable,,, and doubles as a front end weight!! :thumbsup:
/ Best used attachment under $500. #6
Landscape Rake
Bolt on Grapple
Disk
Toothbar
Omni Hitch
Middle Buster (Sub-soiler)
Clamp on Forks
Ken's Bolt on Hooks
/ Best used attachment under $500. #7
Something to work the soil. Ripper, plow, cultivator. Ken Sweet
/ Best used attachment under $500. #8
I paid $100 for my ancient 7' Ford 917 flail. Have about $500 into it now with parts. I'd agree it's my most important implement. Good luck in finding one... there have been 7 posted to Craigslist in Colorado in the past 2 years, most crop flails or overpriced. A rough cut rotary cutter would be the much more likely alternate.
My box blade is #2 on my list. I've done a fair bit of digging & grading with it as well as the expected driveway maintenance. A land plane is on my build or used bargain hunt list. They are easier to use & level/smooth better than a box, but not as flexible.
/ Best used attachment under $500. #9
Really does depend on your land. I would be lost without my landscape rake. A boom pole is also in my sights.
/ Best used attachment under $500. #10
My "most used" for the compact tractor would be 3PT hitch hayforks. Fencing, cutting trees and brush, moving things.
/ Best used attachment under $500. #11
These questions will need to be answered before anyone can give a good answer. In my case as with others a used flail mower was the ticket for mowing my 8 acres and as of last summer the most used implement I have.
That may change as late in the season I bought a 60 inch zero turn and am planning on mowing as much as I can with it. The problem is I have mowed allot of the property with the tractor when it was really too wet and have created tire ruts all over the place. This makes mowing with the ZT a pretty bouncy proposition. Could very well be next summer a plow and tiller will be the most used implements as I plow then till most of the property to level it out.
Less than 5 acres but the real use is as a landscaping tool. I'm saving up for a backhoe but I just might have to stretch for it sooner than later. No grass cutting for me, done enough of that when I was 15!!!!
What I have now:
Rear scrape blade
Subsoiler
Draw bar
Tow hitch w/2"x2" receiver (trailer mover)
Bucket hooks and D-Ring
Filled tires
Lights on ROPS
I was thinking of a set of Edge Tamers but there are some good ideas here.
-R
/ Best used attachment under $500. #13
Tow hitch,hooks on bucket and a chain. Should have $$ left.
/ Best used attachment under $500. #14
Then Landscape rake, many uses.. I use mine mostly for our gravel drive.
/ Best used attachment under $500. #15
Ratchet Rake. Already cleared 1.4 acre in about 50 hours
/ Best used attachment under $500. #16
Surprised no one has suggested pallet forks. Use them as much as anything and less than 500 bucks. Trailer mover is a well spent 100 dollars.
/ Best used attachment under $500. #17
Just getting ready to mention forks and you beat me to it...
/ Best used attachment under $500. #18
I have about 500 in my grapple, use it all the time, next up would be my pallet forks.
For the rear I use my tilt and offset scraper, unless my backhoe is attached.
/ Best used attachment under $500. #19
I have a lot of grass and cover crop in and around my vineyard. For $500, I would get a used 3pt sprayer, and would probably have enough left over to get a small spot sprayer for the quad.
Can't imagine fighting weeds with a hoe.
STORAGE FEES (A59908)
JOHN DEERE 3032E TRACTOR (A62130)
JOHN DEERE 3032E...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2023 John Deere 9RX 540 Track Tractor (A63109)
2023 John Deere...
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
