5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 26,999
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Cannot be much worse that the CACL the road board sprays on the gravel roads out here????
I have a plastic 5 gallon bucket pump I attach a hose to and just squeeze the ball on the pump.... my tractor only takes 5 gallon though... but the pump is super cheap. I think my first one came free with some kerosene... without the pump first time I had a h!## of a mess.My tractor is back from the dealership. Now I have to change the hydraulic oil. It's around 13 gallons, and 10 of those gallons are in 5-gallon pails, so not easy to pour from. Maybe I should have asked the dealer to do it, but based on what they charged for the repair, it probably would have cost me $250 in labor. Plus another hundred or so for imaginative fees.
How do most people put fluid in their tractors? The only opening I know of is a tiny threaded hole on the rear of the tractor, and it will not be easy pouring 5 gallons of oil into it using a funnel.
Same here.
In a similar vein, what do you guys do when you drain it? The pan I use for regular oil changes will only take a little over 6 qt, so that was out of the question, and a 5 gal bucket wouldn't fit. I just ended up draining into a 2 gal pail, putting the plug back in, and transferring to empty jugs. Rinse, lather, repeat.
One extra empty bucket you can pour half in one then pour it all as half buckets. I run 80's tractors bought new or almost. Bale thousands of round bales a year. Changed filters but NEVER changed fluid. Hardly change engine oil. My ride hit 200,000 over a year ago, I think I changed oil once. I just add now and then. No mechanical problems. Neighbor had a 4 cyl mustang, 540,000 miles and changed oil twice. Sold it running too.My tractor is back from the dealership. Now I have to change the hydraulic oil. It's around 13 gallons, and 10 of those gallons are in 5-gallon pails, so not easy to pour from. Maybe I should have asked the dealer to do it, but based on what they charged for the repair, it probably would have cost me $250 in labor. Plus another hundred or so for imaginative fees.
And by now we should all know better than to do that in the first place.Careful now, you are showing your age. If you did that today you could not afford the fines from the EPA popo.
I can use two funnels to pour a 2-gallon pail so I pour into two gallons and then into the tractor for fluid changing. I do plan to make a how-to video the next time I change fluids.My tractor is back from the dealership. Now I have to change the hydraulic oil. It's around 13 gallons, and 10 of those gallons are in 5-gallon pails, so not easy to pour from. Maybe I should have asked the dealer to do it, but based on what they charged for the repair, it probably would have cost me $250 in labor. Plus another hundred or so for imaginative fees.
Thank you and Dawn is about the best oil emulsifier there is. I use it all the time.I dump my oil properly, but I am not under the impression that the world will end if I pour it out in my pasture.
