BEST way to mount 3 point implement: BX2360
   / BEST way to mount 3 point implement: BX2360 #11
All of my implements are on dollies and the garage floor is very smooth. Most of the implements can be pushed with a finger or two. Even the backhoe can be pushed with one hand. Alignment is a breeze and coupling a snap.
   / BEST way to mount 3 point implement: BX2360 #12
Can you post another picture of your dollies and garage for those that haven't seen it? I'd like to also see it again.
Tom is the undisputed KING of space saving and storing of tractor implements, in my opinion.:thumbsup:
   / BEST way to mount 3 point implement: BX2360 #13
Yes, pics! ;)
   / BEST way to mount 3 point implement: BX2360 #14
all m three point hitch stuff set on dollys with a 2x4 plywood on top. that way in my small garage i can move them around very easy and makes hook up easy also. Got the dollys at Harbor freight.:thumbsup:
   / BEST way to mount 3 point implement: BX2360 #15
Yeah, you can't beat those HF dollies...
   / BEST way to mount 3 point implement: BX2360 #16
I pin the 3 point arms as wide open as possible and lowered almost all the way. Then back up to your implement and center one arm ball with the implement pin. I then get off the tractor, unpin that arm and lift the arm to the implement pin. If your tractor has the arm extender adjustment use that, too. Then do the other side the same way. I keep a small pry bar with me to help with unhooking an implement, also. I just pry the ball from the implement pin.
The idea of pinning the arms open and lowered when backing is useful because the arms will flail back and forth and you can't get the distance lined up correctly with the arms out of kelter. Keeping the arms lowered keeps you from having to get back on the tractor to reposition the arm since it was too high and not lined up. It's just easier to manually pick the arm up and position it. I hope this makes sense.
   / BEST way to mount 3 point implement: BX2360 #17
the dollys would work if you have a nice hard floor and space to put it in. I dont.:(
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
12' CONTAINER (A52706)
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
