Best way to pump water?
   / Best way to pump water? #11
What about a PTO pump? I'm not sure what the price would be on a 50GPM unit. Mine is a smaller one at ~12GPM at 540 and ~22 at 1000rpm. Its was ~$120 for the pump and coupler.
   / Best way to pump water? #12
Do you have a 1000rpm pto?
A hypro 1200 4 roller pump will put out almost 49GPM at 540 and 74 at 800rpm.
A 9016-C will put out 70GPM at 50psi at 540, price is ~$550.
The state guy came today & he is a lot more reasonable than their regs say he is supposed to be. Bottom line is they want to get the piles burned as much as I do & are willing to work with me to make it happen.
Soooo, I still need a pump, but the idea is not to use the water to extinguish a rip roaring fire, but one that has burned down to embers & is sending smoke toward Portland. So they will accept a smaller pump, say 20-30 GPM. TSC is the only place I have seen them, does anyone else carry them so I can comparison shop?
   / Best way to pump water? #14
don't blow the tires out on that trailer!!!
   / Best way to pump water? #15
You can do a search on Google, Yahoo etc... TSC seems to have reasonable prices though.
You probably know this but.....Don't turn the hose nozzle off with the pump running unless you install a bypass/regulator. You'll build up a lot of pressure like 300psi depending on the pump.
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2005 military trailer (A53424)
2005 military...
2011 Doonan 482FBCHTTDBZ 53ft 40 Ton T/A Flatbed Equipment Trailer (A52377)
2011 Doonan...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
