Best way to pump water?
   / Best way to pump water? #11
What about a PTO pump? I'm not sure what the price would be on a 50GPM unit. Mine is a smaller one at ~12GPM at 540 and ~22 at 1000rpm. Its was ~$120 for the pump and coupler.
   / Best way to pump water? #12
Do you have a 1000rpm pto?
A hypro 1200 4 roller pump will put out almost 49GPM at 540 and 74 at 800rpm.
A 9016-C will put out 70GPM at 50psi at 540, price is ~$550.
The state guy came today & he is a lot more reasonable than their regs say he is supposed to be. Bottom line is they want to get the piles burned as much as I do & are willing to work with me to make it happen.
Soooo, I still need a pump, but the idea is not to use the water to extinguish a rip roaring fire, but one that has burned down to embers & is sending smoke toward Portland. So they will accept a smaller pump, say 20-30 GPM. TSC is the only place I have seen them, does anyone else carry them so I can comparison shop?
   / Best way to pump water? #14
don't blow the tires out on that trailer!!!
   / Best way to pump water? #15
You can do a search on Google, Yahoo etc... TSC seems to have reasonable prices though.
You probably know this but.....Don't turn the hose nozzle off with the pump running unless you install a bypass/regulator. You'll build up a lot of pressure like 300psi depending on the pump.
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
1269 (A50490)
1269 (A50490)
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
NEW 24ft Feed Bunk Wagon (A55218)
NEW 24ft Feed Bunk...
