big and used or small and new
   / big and used or small and new #1
bdog
Elite Member
Texas
John Deere 6130M
I moved to town and sold my property and tractors about 3 years ago. We are buying a new place with 7 acres. It is flat as a pancake, no trees to worry about getting under,etc.
I plan on doing the typical stuff like mowing, maintaining road / gravel parking area, digging post holes, etc. I also like to hobby farm. At my old place I was running chisel plows, discs, grain drills, spraying, etc.
I used to have two tractors a 47 hp branson 4wd with loader and a john deere 4430 (125hp I think). The branson had a loader so I used that a lot but really I preferred the JD for most other tasks even if it was only plowing up a couple acres.
I have about a 20k budget to work with. I want to stay with green or orange due to dealer proximity. At that price it seems I am looking at around 40 HP or less and open station on a new tractor or if I went with a 80-90's model I could get something in the 65-100 HP range with a cab.
Just curious what everyones thoughts are? I know it seems like overkill to get that much tractor for only 7 acres but I could get things done faster and int he comfort of a cab.
   / big and used or small and new #2
If I had to do it all over again I would get the larger used tractor than a smaller new tractor. You can do more faster with a larger tractor and the problem I am having right now is that a used 2 or 3 bottom plow is about the same price and easier to locate than a subcompact one bottom in this area and it would be so much faster using a 2 or 3 bottom. However I do love having the backhoe where that would have been way over my price range on any other tractor. I can also easily cut around the house and barns with the smaller tractor without needing a seperate mower. The zero percent financing and warrenty are also a plus when buying new.
   / big and used or small and new #3
You Texans sure like to do things in a big way. I can't imagine a 65-100 hp tractor on 7 acres if for no other reason than you get into Cat 2 implements and there expense.
MarkV
   / big and used or small and new #4
I don't think it as much of a question about size, 7 flat acres doesn't need a huge tractor, 30hp would be fine. I think a better question would be do I want to take a chance with hard earned dollars on some one else's head ache? 20k should easliy buy a nice new tractor for what you say your needing. It's your choice as to what brand{color} you want, but don't limit yourself if you don't have to.
Around here the Cat 2 implements is a good thing. They are actually cheaper then the cat 1. We are in a huge farming area and it seems that many years ago all the farmers used cat 2 equipment now they are running cat 3. I have been to several auctions and there is always a lot of cat 2 stuff that goes for cheap as it is too small for the farmers and too big for the compact guys. From what I have seen cat 1 stuff goes for a premium.
That being said I do agree that a tractor that big is overkill for 7 acres but I am just trying to figure out the downside of it. I have a zero turn mower I will use on the yard so no need for finish mowing, no trees really to worry about getting close to or around, no tight spots where it will not fit, etc.
   / big and used or small and new #6
One thing I have never been able to figure out is...Since compact tractors came out, somehow HP got tied to acreage. Which makes absoulety no sense. You can have 100+ acres but not need HP and I can think of things that take very little space and a lot of HP. What matters is the kind of work you thinking of doing. That's what's important. One day I was bored and walked into the local agco compact place. Evidently for my 7 acres at home I need 30hp?
Why? That won't be able to skid logs up a serious grade? Nor will it run my baler. Match the tractor to the work.
So what are you planning on using the machine for?
And I only go for used. Why pay for someone else deprecation. Yes there are deals for new. But I'm seeing more compact stuff being sold cheap. Plus why have a payment for something that isn't making you money?
   / big and used or small and new #7
I think in the Texas panhandle, a cab is the "trump card" in a tractor purchase. Any good tractor with a working cab with air-cond has got to be the best choice. If you are willing to travel a bit and haul in a used tractor, looking on craigslist in Oklahoma and Texas cities can produce some very good deals in larger tractors. I've seen 6 or 8 good Kubota and Deeres in the DFW area listings lately with cabs and advertised as having working AC. The problem is that you have to travel to see them and then travel again to pick them up unless you drag a trailer with you while you are shopping.
   / big and used or small and new #8
Check out Kubota L series 30-35hp..just might fit your price range.
   / big and used or small and new #9
bdog,
If you have been around tractors for quite a while you already know several things about them. I would think you would be better off in the long run buying a new 4320 to 4720 cab tractor. Use it as long as you are able and sell it when necessary. Set it up with top and tilt, IMatch and buy implements that match this setup. Most people don't like a lot of maintainance issues to deal with in retirement.
Do you need one this big? Absolutely not, but you most likely will not want anything smaller than this either. I am betting you miss your tractors and want to get back on them. Life is too short to have a crummy tractor.
If you just want to get a few things fixed and chores done then hire it out, that would be cheaper.
   / big and used or small and new #10
The only problem with the 4520 and 4720 cabbies is they cost around 30K. I would look for used equippment. Or maybe take a look at a used 5000 series Deere with a cab or even a lower 6000 series if you plan to do lots of pulling of ground engaging implements. That should treat you fine. I dont think acerage matters, its the job that matters. My mom sits on 4 acres of land, around here, people reccomend a 25-30 hp tractor. Due to my budget and low amount of tractor work, my 19 hp Yanmar gets the job done. Good luck with your search.
   / big and used or small and new #11
For 7 acres i would like something like a ford 5000 or MF 165 or IH574 , Old and simple and run forever...
   / big and used or small and new #12
My place is only 10 acres of flat hayfield/pasture. My go-to tractor is a 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, power steering, 8F/2R gear tranny partially synchronized) with the ML250 FEL (6-ft bucket, 2950 lb lift capability). Cost about $18K new. I need it to put in my oat hay crop and for general utility work around the place.
The 5525 is pulling my restored Minneapolis Moline P3-6 grain drill (10-ft wide, 20 drops, 6" row spacing) in this photo.
If you have a use for a 40-60 hp tractor, amount of acreage is not relevant. Go for it.
I drive the Panhandle frequently (87/287 and 54) from the Amarillo airport to Guymon, OK to visit my son, DIL and the grandkids.
   / big and used or small and new #13
And always have something to work on when you want to get something done.
I like old tractors as much as next guy but really like newer tractors to work with. Find a nice size 35-40hp with cab new or slightly used and have fun.
   / big and used or small and new #14
Then you bought the wrong one , We have tractors from the 60's and 70's that have 7-8000hrs on them and still do 200hrs a year and if i had to sit down and work it out the new ones are more trouble and have more "down days"...regardless of wether they are 60hp or 360hp.
   / big and used or small and new #15
If you are anywhere near to Spearman there is a good Deere dealership there.
Thanks for all the replies guys. Leaning toward used. Going to go look at a few tomorrow.
I have searched tractorhouse until I was cross eyed. Are there any other good online sources to browse used tractors. I also checked craigslist and ebay.
   / big and used or small and new #17
try ironplanet.com I have found some resonable peices on there and may even find some local stuff. I think it usually is alot cheaper than a dealer and you get a oil report and a inspection report.
   / big and used or small and new #18
Bdog; Try a search for machine trader. They have boat loads of stuff, and you can narrow your search to money, area, machine type etc.....
   / big and used or small and new #19
One thing I am noticing on used tractors is big differences between asking prices and sell prices. Dont be afraid to go low with your offer. Lots of panic selling going on now in this teetering economy. The problems with used is it is tougher to get exactly what you want and there will be more gamble on future maintenence costs. If you are mechanically inclined and not real fussy then it is probably the best way to go these days. When and if the economy gains traction, things will swing back over to new.
   / big and used or small and new #20
i am going through the same thing now except i am in the 12,000$ range and i think i am going to buy a used john deere with loader because you can get more done faster and you have the extra power when needed.
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
40 (A52708)
40 (A52708)
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
Zero Turn Mower (A59231)
Zero Turn Mower...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
