n3gxq
It is my "intent" (key word) to plumb my pole barn for air on my next trip home. I've read a number of posts here, and know that PVC is not the way to go, so metal pipe is definitely what I'll be using. My question is, should I be using black pipe or galvanized for the lines? I won't be running an oil system, as I'll be occasionally painting, and I won't be using tools enough that manually oiling them would be a problem.
I'll be installing a water filter and drops with ball valves throughout the barn. Is the small amount of water in the lines enough of an issue that it even matters as far as potential rust is concerned? I know a lot of this is opinion based, but I've gotten a lot of good information from this site, and am definitely willing to listen to what anyone has to say.
Black pipe will work fine, as will several of the newer products, such as PVC-coated aluminum tubing (no threads - compression fittings) and SOME plastics. Many plastics (and fittings) are just not designed for the pressures that can occur in a shop environment air system.
Regardless what type, always follow these rules: 1. Slope the pipe back to the air source, with a tee & drain valve below the inlet tee for condensate. 2. ALL taps must come off of the top of the air line, then turn to whatever direction you need them. This prevents moisture transfer. 3. All drops should have a drip leg & drain valve on them. All of these are to help prevent moisture transfer. If you plan on using a lot of air and/ or delicate air-operated equipment, consider a refrigerated air dryer.
I ran hundreds of feet of black pipe (mostly 2") in a tool & die shop, using 2-20 hp and 1-10 hp compressors, running 2 shifts per day, back in the early 80's. Still very much in use today! The newer tubing-type products are easier to install, but black pipe still reigns as king of structural integrity. Hope this all helps!
John
