Black pipe or galvanized for shop air lines?
   / Black pipe or galvanized for shop air lines? #181
In my system the tees are mounted in the up position to reduce the moisture from entering the branch lines. It is harder for the moisture to go up.
Also the end of each branch has a drain positioned 12 to 14 inches below the actual chuck mounting position and the chucks are mounted above the drains off of tees with a 90 and approximately 6 inches of pipe then another 90 to position the chucks upward and outward.
Each time you branch out you go up allowing any moisture in the air to drain back and down.
One more thing, although my old system was and new will be rubber lines, the end of the lines/drains/chuck mounting is all 1/2" pipe, iron. Although the ball valves are brass/nylon.
Sorry,if this is confusing.
Any questions ask.
blackdog2086, what did you do for air lines ?
   / Black pipe or galvanized for shop air lines? #183
What kind of shut off's are you guys using? I am using 1/4 turn ball valve shut offs. I have problems with them leaking internally and externally.
Any questions ask.
Nothing yet. I'm still in Afghanistan, but should be home and working on setting up my barn/shop by late summer or early fall. I don't get to check the site as often as I'd like, but I'm still reading responses and weighing my options.
I'm learning about different set ups from all the posts, and not just what to use, but how to install it for the most useful and efficient shop possible. Thanks to all for the info and suggestions.
   / Black pipe or galvanized for shop air lines? #185
   / Black pipe or galvanized for shop air lines? #186
All I used was a threaded to solder adapter on a cheap garden hose house bib from Lowes .. I think each one cost 4 bucks or less. Nothing special needed as it's only water and air. Mine have held up nicely over the years. I don';t get this T thing. It has to go at the top with the drip leg down and the drain at the bottom. That way the droplets pushing along the pipe fall into something to stop them. The TIP company (sandblasters) has or did have a very nice simple diagram on how to set this up and that's the design I used.
I will tell you this though, if you think it's gonna get out all the moisture, especially on hot summer days think again! Mine works ok but even with an 8' vertical off the tank and 30' of nice copper with a drop in the middle and near the end it's not all that great. I get more water from the end one than the middle which tells me it's condensing further down the line for the most part. What you really need and I have yet to build is a CONDENSER like the industrial rigs use. That way you are pulling the moisture out of the air BEFORE it gets into the tank instead of the compressor using the tank as a condenser . There are several on youtube which you can make, some simpler than others.
   / Black pipe or galvanized for shop air lines? #187
I need clean/dry air so the compressor has a finned loop to the tank, the tank has an auto drain valve, the air goes to a dryer with condensate drain and then through a 150' of 1" copper to a regulator with water trap and drain and then to a 2 micron filter with water trap...
The idea is if water makes the 150' there is a problem on the compressor/dryer side.
I had to have it all permitted and inspected and next month will be 20 years of operation 24/7
So far the weak link has been the pressure switch on the compressor... about 5 years is max for the electrical contacts...
   / Black pipe or galvanized for shop air lines? #188
This is the diagram from the TIP website. It's buried in with the Air Piping System content. I did mine like they did and come to think of it I did go up and over to form the drip loop. It will give you a tad more water retention feeding the drop and won't add much to the cost. Every little bit helps although as I said before it won't do crap for the uncondensed moist air, just the condensed real water rolling along the line. Also the more twists and turns in your system the less air flow so you probably want 3/4 lines or more.
The real answer is that condenser back BEFORE the tank. An air conditioning condenser from a big truck or refrigerator works well. Many homemade rigs use a nice big box fan like Wallyworld sells for 17 bucks which sits behind it and is powered off the electric of the air compressor. Anything to knock down that heated moisture laden air BEFORE it gets to that nice big cool tank to drop out. I'm also sure your tank life will go up greatly too.
Anyways that tip diagram is easy to use to work into your potential plans with your own specific modifications. One other thing I never knew for years till I got them . Get ye a set of those rather expensive high flow coupler. I got mine off AMAZON for around 20 bucks for two sets. Their female ends seem to work with my 3/8 Chinese cheapos fine. I keep one hose set up with the high flow on each end which I only use for high flow painting and air gun. Try it your air gun (unless it's chinese junk will show a difference. Some painter said they flow 12CFM which will power anything but heavy equipment air guns like 1" drives so they work as well as the dedicated huge 3/8 couplers that cost awfully. Amazon.com: Milton S-217 V Style Hi-Flow Coupler Kit: Automotive
   / Black pipe or galvanized for shop air lines? #189
No one seems to understand how a regulator affects moisture. A regulator is the cheapest moisture control you can get. A physics review on moisture in air is helpful.
1) . A volume of air at a temperature can hold only a certain amount of water vapor.
2. Compressing the air reduces the volume of air but does not reduce the amount of water present, so as soon as the water vapor reaches 100% humidity then free water droplets form.
3. Higher temperature air can hold more moisture.
So:
Cooling the air reduces the moisture the air can hold and causes more moisture to condense. Cool the air as much as possible before the air gets to the tank. A 150' copper condenser between the compressor and tank would be fantastic.
Once the cool 100%humidity air is in the tank all free water drains to the bottom. Easy to drain. If any free water is in the tank then the tank air humidity will be at 100% relative humidity.
Now the regulator. Take 1 gallon of tank air air at 150 PSI and 100% humidity, and expand it with a regulator so it is at 100 psi. It will occupy about 1.5 gallons of volume.
The larger volume of 100 psi air will be at about 60% relative humidity. There will be absolutely no free water droplets. You will never find water at your tools or end of line drain legs.
Run you compressor at a good high pressure, cool the air if possible, then regulate the air to just above the pressure you need to satisfy all users. To be effective, the regulator installed to minimize free water must be installed at the tank outlet, before the distribution piping.
If this is not clear, ask questions.
For in shop piping PEX with sharkbite fittings is superior to metal.
I'm an engineer at a chemical plant and support a very large air system with two 600 hp air compressors. about 200 acres of equipment. Two regulators at the receiver tank (5000 gallons), no moisture problems.
   / Black pipe or galvanized for shop air lines? #190
Doesn't this only apply if it has cooled all of the way to ambient? Otherwise it will cool more as it runs through the lines. Also the expansion of air AFTER the regulator will cool the air further anyway and force free water to condense in the piping.
I'd have to think there's a reason my plant just replaced their refrigerated drier for like $80k. Of course the screw compressors we use will only build about 100 psi so not much room to regulate down.
CHAMPION 1 PERSON GAS EARTH AUGER (A51248)
CHAMPION 1 PERSON...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
1275 (A50490)
1275 (A50490)
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
