Black pole barn roof
/ Black pole barn roof #1
Engine Mike
Rochester hills michigan
Kubota B2320
I have just about finished my choices for my new 40 x 60 pole barn in Northern Michigan. Down to picking colors. I have picked the side color as Charcoal Gray and White trim. I would like to make the roof black but something inside of me is saying maybe there are functional issues with a black roof. Does anyone know if there are issues with a black roof on a pole barn?
/ Black pole barn roof #2
I don't recall ever seeing a pole barn with black steel,especially on the roof.
I'm thinking the black color would absorb much more heat in the summer,which in turn would cause more expansion/contraction which may stress the sealing ability of the rubber-headed screws that attach the steel to the roof purlins.
I have two pole barns about 25 years old with no roof leaks(knock wood)using the older nails with the rubber washer under the head.
Both have white roof steel;even on a hot day,I can gear creaking and groaning.
Hope this opinion helps!
/ Black pole barn roof #3
I concur with #2, black is going to absorb a lot of heat in the summer.
I am finishing up a 40'x60' gray with white trim now. I went with polar white for the roof.
/ Black pole barn roof #4
I have seen the temperature difference inside hangars by painting a red roof white, it was noticeable.
Black would be substantially warmer.
It is northern Michigan. Still, maybe in Alaska, I would do it.
/ Black pole barn roof #6
There were not a lot of pole barns in Alaska. Pole barn in AK is like a kilt in Siberia. There were barns, especially in the Matanuska valley, but as I remember, they all had light colored or galvy roofs. Actually, the "darkest" barns around here are the old German barns made of brick with shingle roofs.
/ Black pole barn roof #7
I have a dark red (maroon) roof on my stable and hay barn. No issues. It would look nice!!
/ Black pole barn roof #8
I have one on my polebarn as well.
Aside from all the creaking and noises (probably from thermal expansion) on a hot sunny day, none here either.
/ Black pole barn roof #9
For me and MANY others here in N.W. Georgia, the use of chocolate/dark brown is used on homes and barns/sheds when applying new metal roofing. One of my barns is going on ten years now with zero problems............I would think that you would want all the solar gain in the winter you could get........God bless.....Dennis
/ Black pole barn roof #10
Myself and my neighbor both have black metal roofs on our pole barns and neither of us have had any problems over the years.
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
2016 FREIGHTLINER CASCADIA (A60736)
2016 FREIGHTLINER...
2025 Swict 66in Bucket Skid Steer Attachment (A59228)
2025 Swict 66in...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
