blowing/plowing on an incline
   / blowing/plowing on an incline #12
A one year warranty? moship, did your neighbor price out just getting replacement parts? They say it's cheaper than getting new ones.
   / blowing/plowing on an incline #13
Crazyal,
My neighbor would rather buy new versus trying to fix, that's just how he rolls. After 5 years of service he felt he got his moneys worth and was willing to buy a new set. They would likely last significantly longer, but he leaves his on all the time and our ground is very rough. When time comes I'll make my own replacement straps as I already procured a section of mining belt for the task.
Why did he go with rubber in the first place? He used my tractor several times with the metal chains and didn't like the lumpy ride or marking up the neighbors driveways. Plus his tractor didn't have adequate inner fender clearance for them to work. I too was concerned about fender clearance when I got the Kubota and decided to give them a try.
   / blowing/plowing on an incline #14
Moship, I'm in Anchorage Alaska and just build a house on the side of a mountain. Part of our driveway is pretty steep so I'm going to need something. I have turf tires and I'm worried about marring up my driveway with metal chains. As a previous poster mentioned....do you think these would work on a steep icy driveway or would metal chains be the better way to go? We'll end up with a base of compacted snow that turns to ice within a couple weeks of the first snows. After that it's all winter clearing snow off the ice. If you think these rubber chains will work well on ice I'll give them a shot as it sounds ideal to keep from tearing up my driveway and garage. Also, I'll be mounting these on a BX2230. Will they clear the front arms that are so close to those front tires?
Anyone else have experience with these rubber chains on steep icy driveways?
   / blowing/plowing on an incline #15
On pure ice nothing is going to work as well a metal chains specific to the task. I've gone up and down some gnarly driveways and there are times I wished I had something besides the rubber chains. If safety is a question I'd error on the side of caution and stick with ice specific chains and live with the surface wear that comes with it. Also keep in mind your tractor is a lot smaller than mine, so once I get sliding it takes a lot more to get stopped.
Considering the cost I'd take the risk and try them for your particular situation. If they don't work I'm certain you could sell them for as many BX owners that are out there.
   / blowing/plowing on an incline #16
What's the problem if a driveway gets marks on it? Is that a social faux pas like wearing white after Labor Day?
   / blowing/plowing on an incline #17
CobyRupert,
Good one! Watch out or the fashion police will get ya!
I for one am not worried about cosmetics. My concern is accelerated damage to the driveway. With the cost of paving, you want to get as many years out of the blacktop as possible. A little scratching is no problem, but would gouges lead to ice-cracking and deterioration? Maybe those out there who have older driveways can tell us that they have been scratching the heck out of them for 15 years and they are fine, and if so, we could just put this to rest once and for all.
My drive is only a couple of years old, and on the steep sections, I had to do what I could to get up in the icy conditions. You can see some scratches and a little surface damage. However, I kept it to a minimum, as in avoiding useless spinning of the wheels, etc. I would like to hear the opinion of some who have older driveways if this is an issue or just a 'bogeyman'.
Frank
   / blowing/plowing on an incline #18
CobyRupert,
Frank
Frank beat me to it. In Anchorage we get 6-9 months of snow and ice and constant freeze thaws during the winter. Like he said asphalt is expensive and I want to make this thing last as long as possible. If folks aren't having any trouble with using chains on their drives then I'll buy chains as I can get them locally made to custom fit my tractor for the same or cheaper. But I'm just trying to figure out how to handle snow and not tear up my expensive new driveway.
If anyone has any other thoughts or advice keep them coming. Moship...thanks for the help.
   / blowing/plowing on an incline #19
I have a Kubota b7610 and use it to plow commercially. It has a soft cab with heat and a front 60" blade. I have r4 tires on it. The rears are filled. Several years ago we plowed a condo assoc with hilly drives. We might be doing it again this year. The tractor would often have problems with the inclines. I purchased chains for the rears, which helped, but the design gave a horrendous ride. So bad we removed them. I'm considering buying r1's just for the winter. Would studs help? I used them on my track skid steer with success on a different hilly property. The only downside was they scratched the pavement to ****. The following year they sealed the pavement so I couldn't use them. What ways have you found to gain traction?
On a side note, I am planning on a rear blower in addition to the front plow, so I should have decent ballast. Haven't decided on which unit to buy. Will be 50-60" wide. Thanks.
Sounds like your setup is going to be close to mine. I have a JD and quite a hill to plow. First year I had problems so last year I picked up a set of "Rubber Tire Chains" so I didn't rip up my driveway then a ballast box filled 1/2 with solid cement blocks then sand salt mixture. Worked OK. I'm expecting delivery of 60 inch 3 pt. which will be heavier than the box hope that will do it for me. I did like the chains bit bumpy but did the trick with no damage.
Sent from my iPad using TractorByNet
   / blowing/plowing on an incline #20
I run ladder chains on R-4s. They don't wear asphalt much if you don't spin, it leaves tiny white marks all over though that clients don't like. If you spin you will damage the pavement in a hurry. R1's are only better than R4's if you get skinny ones. Turf's have much more snow/ice traction. My other tractor has R1W's in a large metric footprint, I can't use it without chains on it in the winter, it simply can't move with any snow or ice on the surface. Even in 4wd with both front and rear diff's locked it can't get up a plowed driveway. Really embarrassing actually.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
Tires (A50322)
Tires (A50322)
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
