fatjay
Elite Member
I was working with my bobcat m600 moving dirt. All was going well then something happened. Engine pitch changed and started blowing white smoke. It was a sudden change, not gradual. Any idea what might have caused it?
Many things could be the cause. Did you get it hot, are you sure your temp gauge is working? I'm thinking overheat and popping a head or head gasket. Water in fuel could cause some white smoke, but doesn't sound like it with the symptoms you describe. Are you losing coolant?
I had that engine on a Vermeer Stump Grinder. I seem to recall I once had the oil issue and attributed it to stuck valve. But, I don't think it ran and then had issues, rather it was the first start of the season kind of thing.
It's AIR cooled so it can only be oil that it's burining.
