Bobcat wood splitter, how to hook up?
   / Bobcat wood splitter, how to hook up? #11
This is what the original poster said.
[ I bought a wood splitter homemade 3 point tractor set up .]
Although he could adapt it for upside down cut and move the valve in the cab.
You would remove the valve (no need for it) & mount the splitter upside down on a quick attach plate, a 773 is a skid loader, not a tractor. I have a homemade 3 point I built 30+ years ago I did this to.
   / Bobcat wood splitter, how to hook up? #12
Bigkrank,
You have to have some kind of valve to make the cyl extend and retract.
What kind of valve are you using to power the cyl on your log splitter.
Is it lever or switch control solenoid valve, and is it motor spool or what.
Are you using fwd and rev to supply fluid in the extend and retract.
Just curious.
What I am getting at is , do you have a log splitter valve to extend and auto retract, or do you have to hold the switch one direction and when split, push it in the other direction for retract.
   / Bobcat wood splitter, how to hook up? #13
The Bobcat already has all the hyd controls inside. Controlled with a switch on the joystick. No need for a person on the outside. Watch the video in the link, lots of those types being made in shops around here.
   / Bobcat wood splitter, how to hook up? #14
   / Bobcat wood splitter, how to hook up? #15
I have variable and max flow, not sure what his 773 has. Much faster and cheaper than the old gas tractor it was on before when it was 3 point.
The one in the video seems slow because of the large diameter cylinder which is needed because of the multiple splitting wedge. May be just as fast in the end.
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A54757)
UNUSED RAYTREE...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2011 INTERNATIONAL DURASTAR 4400 (A53843)
2011 INTERNATIONAL...
