Bolt sizes Metric?
/ Bolt sizes Metric? #1
botayota
CT River Valley - NH
Kubota L3240Hst
Looking to find out if most of the bolt sizes on Kubota tractors are metric or US?
Not sure if it explains this in the manual?
/ Bolt sizes Metric? #2
I have had 2 70's vintage Kubota's, and they are virtually 100% metric (which I'm really starting to prefer once gotten used to)
Dunno about the newer ones though, but I presume the same. (Except for perhaps some farmed out U.S. made add-ons.) If I recall corectly, my recent retrofit ROPS was all metric where it bolted up to the tractor, but the splice plate to joint the two halves at the top was SAE.
Sherweld
/ Bolt sizes Metric? #3
Only non-metric I've found on my BX24 were the lug bolts, which surprised me.
/ Bolt sizes Metric? #6
Remember this.....3/4" and 19mm are virtually the same size! I highly doubt they would put SAE lug nuts/bolts on the machine.
Craig
The thread is an SAE pitch and the stud dia is inch. Those are hex sizes youre referring to, and youre right that the size matchup is verry close.
larry
/ Bolt sizes Metric? #8
From what I have noticed on my B7100 the tractor is metric and the attachments such as the loader and mower may have a mix of nuts and bolts holding them together.:D:D
/ Bolt sizes Metric? #9
Craig
Well they did. The lug bolts are 1/2x20 found that out when I found a factory assembled screw up on one of mine, I figured they'd be metric but weren't.
We aren't talking about what WRENCH may or may not fit. We are talking about FASTENERS.
If you really want to get confused go measure the front and rear lug bolt HEADS on a BX24. They are different, take different size tools, but they both have 1/2x20 SAE thread on the fastener.
Now for a pet peeve of mine on a motorcycle forum I'm a member of- guys constantly refer to a bolt size as say 10mm when that is the HEAD size for a tool. That would be like calling a 1/4 SAE bolt a 7/16. They also refer to a socket head bolt as a hex head which is also incorrect, a hex head bolt is a REGULAR bolt, or more correctly a cap screw but you get the idea, a socket head bolt (cap screw) is just that. I've given up on the motorcycle guys with this, lets please not get that way here:D
Thanks for all the info on this topic... I did notice that there are always some SAE wrenches that are close to the metric sizes and they fit fine, plus luckily I've got a metric set.
/ Bolt sizes Metric? #11
Sherweld
What I dislike about Metric is that for a given bolt size there may bo 2 or more head sizes. (at least thats how they are in Australia)
And then there's at least one size,think it may be 10mm, where there is a third pitch, not just a coarse and fine.
/ Bolt sizes Metric? #12
the ones that are close (that I use frequently) are
  1. 6.5MM=1/4"
  2. 8MM=5/16"
  3. 14/15MM=9/16" (depending on the maker of the wrench/bolt and how well made it is)
  4. 17MM ~ 11/16"
  5. 19MM = 3/4
  6. 24MM = 15/16
  7. 25MM ~ 1"
Legalese: this not a complete list, it is provided as-is for information only and is not guaranteed to be accurate, I am not responsible for any broken tools, parts, or people as a result of this information.
Aaron Z
/ Bolt sizes Metric? #13
Agreed (although I haven't encountered that {yet} on Kubota) ...... but then I have run into the same thing with "our" sizes. Particularly annoying when the wrench brought from the shop will only do three out of the four nuts to be removed, requiring yet another trip to the shop to remove the heavy duty size. :mad:
I will say, that the metric thread pitch(s) still confuse me a bit though.
Regards
Sherweld
/ Bolt sizes Metric? #14
On many Kubotas sold in the US, the ROPS/FOPS and loaders are made here,
so they have SAE bolt (machine screw) sizes.
You can often tell metric vs SAE with a quick glance at the head. An SAE
bolt of grade 5 or better will have radial hash marks on it and a metric
will use a grade mark like 8.8 or 10.8. For Kubotas and some others (like
Toyota) you will find a grade rating like 4 or 7, up to 11 or 12 on the
head. In this case, the # marks fill the head and there is no standard
mark like 8.8 for these metric bolts.
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2025 Rippa IREAS Ripper Mini Excavator Attachment (A64553)
2025 Rippa IREAS...
INTERNATIONAL 700 SERIES 6 BOTTOM PLOW (A64278)
INTERNATIONAL 700...
Star (A64557)
Star (A64557)
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
