Boom Mower
/ Boom Mower #1
SnowRidge
Elite Member
East Tennessee
Power Trac PT-425 / Branson 3520
Having managed to acquire some property with steep, overgrown roadsides that couldn't be simply or safely bush hogged, and was far too extensive to hand clear in the 90+ heat, I reluctantly came to the conclusion that I needed a boom mower. My first choice was something that would fit on my Branson's TPH, but the breath taking prices convinced me to look toward Tazewell, however reluctantly. A trip north for the acquisition resulted in one boom mower, a considerably lighter wallet, and all the usual paperwork that accompanies most PT-425 implements, one lonely receipt. PT didn't even supply dust caps for the two hydraulic hoses that couldn't be connected together. :confused:
The current production boom mowers are a little different than those shown on the PT web site. The motor's apparent case drain line is plumbed directly back into one of the PTO hoses right at the motor. There are no extra lines running back to the PT, as it appears to show on the web site. The mower is boomed to the right instead of the left, as is shown on the web site.
PT has virtually no description of the boom mower on their web site, and the only person there that seems have any knowledge of the product is, of course, Terry. The sales team is "unfamiliar" with the product. I was shocked. :rolleyes:
Exactly what the company had in mind when they designed the thing is open to question. While it has a single blade, like a finish mower, it is very thick, more like a brush cutter blade. In fact, it will cut saplings to at least one inch diameter. If I had to characterize it, I would call it a mini brush mower on a boom. Whether that is good or bad depends on your point of view, if there are bystanders or not, and how well armored you are as operator. More on that subject later.
The mower's blade measures 20.5 inches tip to tip, more than living up to the advertised size. The up and down travel of the boom arm is controlled by the quick attach lever. The deck itself is attached to the boom with two large bolts. It is free to swivel, although the bolts can be tightened enough to sort of keep it in one position. The mower is positioned for use by a combination of lift arm height and boom height and/or PT positioning. The quick attach angle must be corrected for boom height. Used this way, the raised boom pivot point functions in a manner similar to that of a knuckle boom mower, although it is far from an exact parallel.
More to follow.....
/ Boom Mower #2
Are you sure you didn't install that upside down ;-) That thing looks crazy... I am really not sure about that design. Have you used it yet?
Ken, is this what yours looks like?
Carl
/ Boom Mower
Grass mowing.
Operation is fairly tricky. It is a real chore to try and keep the mower deck level on anything but billiard table smooth ground, of which I have exactly none. The natural rolling of the PT exacerbates things, and the operator soon develops the dreaded Tazewell Hunch from being bent over to reach the quick attach lever, which requires constant adjustment. Most of the time, the lift arms and tilt need to be tweaked as well. You stay busy mowing with this thing.
The deck should be held just above the ground, lest you damage the blade attachment nut, which is exposed to any rocks you might find. They did warn me about that in Tazewell. Fitting wheels to the deck, as has been suggested here in the past, will not work, simply because there is no float position for the quick attach control. If there was, and the deck had wheels, it would be a whole lot easier to mow with.
More to follow.....
/ Boom Mower
Brush cutting.
You don't "mow" the brush, you actually attack it from above. The mower deck is positioned above the brush, then lowered onto it. This was also explained to me in Tazewell, and it appears to be the only useful way to cut brush with this thing. It generally takes two or three swipes to get most of it. It seldom gets it all, though, unlike the standard brush cutter.
More to follow.....
/ Boom Mower #5
Carl
Carl, Whatever are you talking about. It looks just like the one on the attachment page, except that is mounted with the boom to the right. The mounting , lift arm, motor are quite normal.
SnowRidge, how much can the arm be lowered or raised from horizontal?
/ Boom Mower
Issues.
You just knew there would be issues, didn't you? :)
First, this thing turns the normally wonderfully stable PT-425 into a rolling carnival ride. It's a whole new kind of PT pucker. There is so much weight out to the right that you can actually roll the machine if the mower is high and you are on a slope canted to the right. A counter balance is needed badly. If the machine is leaning to the right, raising the lift arms moves the mower deck farther out from the machine center line. If you are on enough of a slope when that happens, the whole shebang will roll. :eek:
It also feels like it would roll if you made a fast turn to the left with the mower high. Needless to say, this thing requires extreme care. I would not recommend that anyone buy one of these boom mowers unless they had more than just a few hours on their PT-425. You need quite a bit of experience to keep it within the safe operation zone.
The normally overly sensitive PT controls make things worse. If you have a lot of weight out there, the fast quick attach control can make the mower move so fast that the entire machines rocks side to side. And you have to use the quick attach control a lot, because of the mower's design. The boom cylinder is so far inboard that it can't hold position and leaks down badly. There is a tremendous moment arm working on that cylinder. Running the mower requires constant jockeying of the positioning controls.
You also need a full face shield. Body armor would also be nice. The mower is out in front of the operator, and it throws all manner of stuff back at you. Believe it or not, the mower rotates clockwise, as seen from above, and sends the debris straight for the tractor. :mad::mad::mad:
I figure that is why they originally had them rigged to the left. They probably changed to the right due to complaints about watching left while working the quick attach lever hunched over. You can change it to the other side, but some of the hydraulic fittings have to be removed because they won't fit through the guide loops.
Speaking of the guide loops, take a look at the last photo. See the cuts in the hose. That is after being installed and used on my PT only twice. The loops are made of strap steel instead of round steel, and they have already exposed the steel core of one hose. :mad::mad::mad:
OK, those are my thoughts for now. I'll probably have more for later, and I know there will be questions.
Discaimer: No SnowRidges were harmed in the making of this report. :p
/ Boom Mower
Gosh, the one thing I did not measure. It goes up at least 45 degrees, I would say. I did not expect much down, but there is quite a bit. Down slope side mowing can be done.
/ Boom Mower #8
Hi Carl,
You are right - his is very different than mine. Mine (the one for the slope mowers) has a counterweight and with some work, the mower can be mounted on the left or the right. When using, the loader arms are locked at a height which allows the counterweight to be about 18" off of the ground.
Attached is a picture from PT's web site.
Ken
/ Boom Mower #9
Carl, Now I see what you are comparing. That other mower is called a knuckle boom mower. PT wants $4,200.00 for that mower that fits a 1445.
Boom mower for the 425 is $1700.00
/ Boom Mower #10
These boom mowers are pretty scary. The big commercial ones aren't too different, although the operators tend to be in enclosed cabs.
You can get lightweight body armor from most tack shops that serve three day eventers. Mostly, they are herringbone hard foam, but it is a lot better than nothing.
As far as I can tell, PowerTrac just cuts the steel plate to make these tractors, with no bevelling or rounding of edges. I found a hose cut to the wire inside the tunnel- it had been cut during installation.
I wrapped all of my exposed hoses in hose wrap, and then wrapped more hose wrap around those loops. I had seen cuts in hoses at Tazewell, so I figured it was going to happen pretty soon after power up.
I also used some 1/4" car door edge strips pushed onto the sheet steel openings where the motor hoses pass through to the wheel motors, and around the tunnel openings L/R, and up. On my 1445 there was a knife sharp edge just as the steering hoses bent upwards. I cut my hand on it reaching in to have a feel around.
It looks like a counter weight wouldn't be too hard to rig, but I also wonder about how much weight you already have out there.
Have fun,
Peter
SnowRidge said:
Issues.
/ Boom Mower
I have never found a cut on any of my hoses before. Perhaps I have just been lucky.
I have a tree timming chap that I can use to protect my right leg. The knee cap is my main concern on the leg. I have already taken a 1 1/2 inch long hunk of 1 inch sapling there, and it hurt like the dickens. Leather gloves and the face shield protect the other areas that concern me. I'm not too worried about anywhere else.
I am considering swapping it over to the left, and replacing those hose straps with round stock at the same time. I just haven't decided yet if it would be worth it with the control still on the right.
I am considering a counter weight, but I have yet to convince myself that I can do it without adding more problems than it would solve.
/ Boom Mower #12
I am not normally scared of things flying around but that thing would scare the crap out of me :eek:
I have used a flail boom mower on the back of a cabless tractor before and that was pretty scary. You had sticks flying at you from all over. And the flails don't even chuck things that much.
But that thing with a spinning blade and very little operator protection mounted in front of the operator must be crazy!
I can't believe they can sell them and not be worried about people suing them for the loss of eyes and the like?
I have seen someone with a hedgecutter that had what looked like three circular saws with no guarding at all for cutting down trees along a hedge row. But he uses a semi armoured tractor with full cab and had to be very careful with flying debris and cars.
/ Boom Mower #13
And some folks on here thought it was dangerous to lift their brush cutter up a foot. That thing reminds me of a story I heard once about a guy that picked up his rotary lawn mower to use as a hedge trimmer. Now that you have bought it, I guess you have to use it, but I would find a way to attach heavy plexiglass, or something, to the front and right side of your rops.
/ Boom Mower #14
Here are 2 things that if one is willing to do helps stability when side mowing.
I have done a right smart of side mowing with mine and a counter weight if sticking out gets in the way (very aggravating to me).
Number 1. Reverse the front wheels but you might won’t to put them back to normal before lifting heavy loads with other attachments. I just try to do all my side mowing before doing anything else. It’s a little bit of trouble to swap wheels.
Number 2. Buy a spare tire and rim, fill it with tractor tire fluid and put it reversed on the opposite side of the mower. I wouldn't want to run it anytime but when side mowing though, hence the spare.
Another thing. If you haven’t modified the quick attach to come out high on the other side easily reached with the left hand You would really like that. A few PT owners have done this and I can’t even imagine having it back the original way!!!
Another thing. I have been thinking of putting an orifice in the side mover cylinder hoses to slow the up and down movements.
Using a schedule 80, ¼ inch nipple. Tap the inside so a set screw will fit. (forget what size but that should be hard to figure out) tighten it inside the nipple and drill a hole in the set screw( Don’t know what size, guess I’ll will have to figure it out trial and error)
Maybe someone can help with the drill size?
/ Boom Mower
stray said:
Another thing. If you haven稚 modified the quick attach to come out high on the other side easily reached with the left hand You would really like that. A few PT owners have done this and I can稚 even imagine having it back the original way!!!
Is there a thread on doing that mod? I looked, but could not find one. What am I missing?
/ Boom Mower
Number 1. Reverse the front wheels but you might won稚 to put them back to normal before lifting heavy loads with other attachments. I just try to do all my side mowing before doing anything else. It痴 a little bit of trouble to swap wheels.
Thanks for the suggestions. Unfortunately, right now I don't have any place to work on anything at the property I use the boom mower on. I would hate to get into changing or reversing wheels over there.
/ Boom Mower #18
Not going to recommend it to anyone... but I've been running loaded tires and reversed wheels for over 200 hours now with no problems...
I'm willing to "risk it" but I won't recommend it...
http://farm2.static.flickr.com/1317/690037545_8aaaa9818f.jpg?v=0
/ Boom Mower #19
Have you thought about installing an electric solenoid valve in place of the aux PTO valve? You could then put the electric operating switch on the joystick and operate the boom mower lift with the joystick. It might make it easier on your back.
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
72" JCT TILLER (A62613)
72" JCT TILLER...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
STEPP SEALCOATING MACHINE (A59914)
STEPP SEALCOATING...
